2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
275 Questions View all
MacBook Retina Pro 2013 - Broken Right Fan ZIF socket
I recently spilled beer on my laptop (Early 2013 15' Macbook Pro Retina), resulting in some corrosion on the connection between the logic board and the top case/keyboard. I soaked it in iso alcohol and removed the corrosion with a fine brush. After putting it together, it works fine (as far as I can tell)!
Unfortunately, when re-assembling the laptop, I broke the retaining flap on the right fan ZIF socket. For reference, it's the socket shown here:
https://d3nevzfk7ii3be.cloudfront.net/ig...
The socket is still intact, and the cable fits in it, but I think without the plastic latch/flap the cable won't engage. I put some electrical tape under the cable to hold it parallel but that doesn't help it engage with the socket.
I ran the apple hardware diagnostic tool (startup while holding the 'D' key) and it gave me this error - 4MOT/4/40000002 - Right-Side-0. It seems like the laptop can't recognize the right fan without the socket being locked down.
Is there any way to fix just the flap? Or the ZIF socket? I have some experience doing SMD soldering so it's not out of the realm of possibility to replace the socket itself if I can find the part.
Score 4
1 Comment
Thanks! Do you know any UK distributors that stock this part?
by
Add a comment
Chosen Solution
Cam Bennett, the connector is a FF14A-5C-R11DL-B-3H. It is available at places like this and many others. The only proper way to fix this would be to replace the connector.
Score 2
Add a comment
How did you fixed this? Same problem here
1 Comment:
I'm sure Cam got the replacement connector from part info and link @oldturkey03 gave her. Then either had the skills to replace it or got someone with micro soldering-skills to do it for her.
by
Add a comment
Add your answer
Cam Bennett will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 10
All Time: 1,473
