Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
301 Questions View all
Wiring schematic for 88 Chevy pick up
Turn signal and brake lights do not work on my 88 Chevy pick up hazard lights do work it one time there was a fire in the Dashboard melted the wires . I need information on what color the wires are for their turn signals and brake lights and where they are located
Score 7
1 Comment
How to wire in a light for a compass. Requires a 1 amp fuse for my 1988 Chevy 2500 pickup
by
Add a comment
Most Helpful Answer
Mark Eggleston, that is a tall order ;-). Check the diagram first
and then read through attached Silverado 1988-2005==>> CHEVROLET-SILVERADO-1988-2005.pdf<<== wiring diagram. Personally I'd replace the complete wiring harness. Anytime you've had fire damage you'll always run into more molten cables etc. It's a bit of a PITA to fix that by splicing and rewiring.
Score 2
1 Comment:
Thanks a bunch Mark Eggleston. I was looking for the parking light wire under the hood to attach the parking light flasher on an alarm. It's the brown wire on the driver's side run along the top of the innder fender.
by
Add a comment
yellow for left and green on right side
Score 1
Add a comment
Sounds like the turn signal switch. possible it's unplugged or the worst case you have a rodent problem . They love wiring insulation. Both brake and turn are on the same circuit. Hope I helped. Good luck.
1 Comment:
@jamesnydegger "there was a fire in the Dashboard melted the wires"
by
Add a comment
Add your answer
Mark Eggleston will be eternally grateful.
Past 24 Hours: 16
Past 7 Days: 135
Past 30 Days: 694
All Time: 33,019
