Why can I only hear sound in one ear?
I am able to hear the sound in my left ear when i use the headphones.
I have the same issue here.
I found that is the black cable who goes inside the headphone and connect the right speaker.
It's a bad contact or something like this, I'm checking how to fix it.
For me appears to be the cable of RIGHT side. The Speaker is OK, but the cable that connect to "R" (right) is broken!
I will check.
This happened twice with me.
Now appears to be fixed. The cable was broken inside headphone and inside the box with volume control.
Your right speaker is probably blown. Please refer to the repair guides for this device for information on how to repair it. Following them step by step will make for an easy repair.
Mine is fine unless i put it in a xbox one controller.
Where can I find the repair guides?
for mine it works on my pc fine but when i hook it into an xbox one controller one side doesnt get enough juice so it doesnt work might need an ac adapter for the controller not sure if it helps anyone but hopefully it helps
I need photo’s of where the wires go on the left side speaker - some came loose but no idea where they go to be able to re attach them.
Hi, not sure if you still need this, but my z11's just crapped out on me. Left speaker stopped working. Thought it was a loose cable, but it's not. At any rate, I saw your comment about needing photos before I reassembled. hopefully this can help! https://imgur.com/EPYAjZF
Past 24 Hours: 6
Past 7 Days: 34
Past 30 Days: 163
All Time: 53,140
