An affordable Windows phone by Nokia, released April 2013.
81 Questions View all
Cant open any applications even after hard rest
Phone was working pretty well since the last three years. Last night suddenly, all of my applications stopped working. Even after hard reset and again downloading all of the same applications they won't work. What could be the matter ??
Score 8
13 Comments
Hi,
Did you update any apps or the phone just before it stopped? If so can you remember which app? If so uninstall it and see how it now goes. If you didn't do anything like that, when you hard reset, did the preloaded apps (the ones that came with the phone) work? The phone must be working of a fashion, you said that you downloaded all of the same apps again. Maybe one app has again altered something on installation and that has affected the rest. Just an idea. Maybe you could try to hard reset again. Check that the phone works and that the apps already installed work. Then start downloading your apps one at a time and trying them. When you are satisfied do the next one etc. Long process but maybe the only way to find out.
by
1.I didn't update any app or my phone.
2.The preloaded aren't working either. I did a hard reset and downloaded a completely new app. But that new app is also not working.
3.I uninstalled all the same apps again and did a hard reset again. And downloaded a new app. But... same problem.
4. WhatsApp, OneDrive, Music Player,Video,etc. aren't working (after two hard resets)
by
Hi,
Is this link of any help to you?
http://www.microsoft.com/en-au/mobile/su...
by
I'll try that way and revert back soon :)
by
thank you so much :d :d :d it worked !!!
by
Show 8 more comments
Add a comment
Most Helpful Answer
Are the Phone in SAFE MODE ??? App are installed in SD memory Card or In Phone Storage ?
Score 1
1 Comment:
Yes my phone in safe mode And app is install in phone storage my name is Rajat
by
Add a comment
Sounds like a software issue.
Try doing a hard reset using the following software
https://support.microsoft.com/en-gb/help...
Add a comment
I will try plugging in the wall and doing the hard drive hard reset
Add a comment
Add your answer
rohiet bhoslay will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 18
All Time: 13,214
