Sony Cyber-shot DSC-W150 is a 8.1 megapixel point and shoot camera with a 2.7" LCD display.
15 Questions View all
Sony Cybershop DSC w 150 why are my photos extremely over exposed
suddenly all of the photos are very over exposed. I have reset the camera to factory specs but it hasn't helped. Its like its stuck on an iso of 3200.
The auto modes don't help.
Is it likely to be a problem with the sensor?
The images are very pale with visible horizontal white lines very close together
Add a comment
1 Answer
Chosen Solution
Did you try selecting High ISO sensitivity?
Also, set the White Balance to “Cloudy”. You can also set this option to “Daylight” as it is suitable for different outdoor conditions.
Score 3
9 Comments:
Adjustments to the white balance make no difference
Where do I select High ISO sensitivity? The ISO palette only includes auto, the 80 to 3200 depending on other settings, i.e., no 'High ISO' mode
by
Duh! Yes, there is a high sensitivity setting on the mode wheel, but selecting 'High sensitivity' makes no difference to the result, the images are still extremely over exposed. If anything, it makes toe problem worse.
by
If the issue persists, initialize the Camera to factory settings:
MENU>(Settings)>(Main Settings)>[Initialize]>[OK]
by
I have initialised and reset the camera to factory settings but the problem remains
by
Ok, so I'm guessing it's fine, when you look through the lcds. But, after capturing the image, and viewing it, with the LCD, it's all white and blurry?
by
Show 4 more comments
Add a comment
Add your answer
Coleen will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 24
All Time: 1,482
