Why does vertical line appear on documents using ADF as source
If I copy from the flatbed everything works fine. However if I copy or scan using the ADF, then a black vertical line appears down the center of the output document.
I wonder if there is dust or dirt in the ADF causing the line to appear, if so where can I find instructions for opening and cleaning ADF.
Score 11
9 Comments
Didnt work. Cleaned the entire ADF area and nothing helped
by
Cleaning didnt work. The line is very straight, top to bottom, not smudged like dirt. Almost like a scratch.
by
cleaning did not work. is there any other solution
by
I have no narrow strip of glass on my scanner
by
IT WORKED! Cleaned the small space of my Epson WF-3530 with alcohol and cotton ball. My documents (scanned, copied, faxed) have had red streaks for over 2 years or so.
I'm excited the problem is solved and was free to resolve. :)
by
Show 4 more comments
Add a comment
Chosen Solution
Hi,
Here is a link to the User Manual that shows how to clean the ADF area and rollers. Scroll down to Cleaning and Transporting your Product, click to open then click on Cleaning your Product
https://files.support.epson.com/docid/cp...
Score 16
14 Comments:
clean the small glass. worked!
by
Cleaning the small glass worked. Thank you
by
This is so cool!! thank you!!!
by
yes cleaning glass did the trick . thanks
by
Cleaning the narrow strip of glass on the left worked - also vacuumed the left side to remove dust. - Thanks
by
Show 9 more comments
Add a comment
This problem occurred with my Epson WP-4530 when using the ADF to scan. Epson manual says to avoid chemical when cleaning the ADF, but I could only remove the lines by using alcohol. Dry cleanig wold not work, but alcohol worked great!
Score 2
1 Comment:
Thank you, thank you! I removed the lines using rubbing alcohol and a microfibre cloth on the glass, the clear plastic on the ADF, and all around the clear plastic on the ADF. Clear as a bell now!!
by
Add a comment
It took spraying condensed air on the rollers to clear up my problem.
1 Comment:
Cleaned small glass panel on left. Small ink blot removed with alcohol. Removed line on feeder and feeder scan copies.
by
Add a comment
Tried wiping the ‘small glass panel on left’ with a dry cloth but this didn’t help. Went at it again with a cloth dampened with alcohol screen cleaner and problem solved.
2 Comments:
Like some others who've posted, I inspected the small glass panel...subtle amounts of schmutz on it. Took some Windex and elbow grease to remove it. BUT......the effort was worth it......the two vertical black streaks on all my ADF-scanned documents were GONE !
Thanks for the suggestion.
by
After using microfiber with alcohol it's gone.
by
Add a comment
Add your answer
rglee46 will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 98
All Time: 39,054
