The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
224 Questions View all
iPhone 1G front panel kit
change iPhone 1G front panel kit
I need that part, and I can't find it on iFixit. It used to be there 3 days ago. Can you help me with the link on iFixit?
Update
Are the 1st gen digitizers the same as the 3G digitizers?
Score 4
Add a comment
Most Helpful Answer
the digitizer for the 1st generation iphone is connected directly to the lcd screen as well. so its like a combo screen. its not compatible with 2g or 3g because it has different connectors
Score 3
Add a comment
These are all the parts that are available for purchase for the 1st generation iPhone.
As Alex mentioned, the 3G digitizer is not compatible with the 1st generation. Further complicating things, the opening procedure for the phone is very difficult, so you should definitely read through the guide before attempting to replace the display assembly.
Score 2
Add a comment
if the link is gone, it means they run out. its gone mate...
Score 1
1 Comment:
by
Add a comment
i need a front panel for a i phone 1g and a repair kit fot it to
Add a comment
Add your answer
Sameh Mousa will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 18
All Time: 11,278
