The Huawei Ascend G610 is a 5.0-inch Android smartphone released by Huawei in 2013. The G610 includes models G610-U00 and G610-U20.
30 Questions View all
My Huawei g610 restarts continous, Logo appears only for few seconds
My Huawei g610 has restarting fault, Main screen appears only for few seconds and it again restarts. Checked softwares and hardwares technitions, they advise to change the mohterboard. is there any other solution. please help.
Score 21
1 Comment
huawei g610 not on . connect power supply power on .17to.19 in power buttn then 0 . charg conect only charg red light on
by
Add a comment
Most Helpful Answer
hello even what I had had the same problem but it was only a cover that had broken near the power button holding down the button
Score 1
Add a comment
Same problem,, Any help?
Score 1
Add a comment
step 1->change ur mobile firmware
http://consumer.huawei.com/pk/mobile-pho...
may be power button short check and proceed
Score 1
1 Comment:
how to change it while the mobile is keeping restarting ?
by
Add a comment
I faced the same problem! But my phone was in warranty so i go to the huawei franchise and they said that it was the board problem and need to change the board! After changing the board, my phone works perfectly!
Score 1
2 Comments:
How much the board costs?
by
The board or to be more specific ,the chipset ,costs between 2000-4000 PKR(rupees). Buy a second-hand phone and it'll cost about the same.
by
Add a comment
I tried it but nothing changed . It fails to factory reset and it doesn't pick the new firmware.
2 Comments:
hello, have you tried to disassemble the phone and check the contacts of the button and the battery charging socket? Sometimes dirt can make jokes
by
Yeah tried it. :(
by
Add a comment
Your phone should have to upgrade or downgrade firmware. Or you have to should check your battery.
Add a comment
I have the same problem with the logo and vibrate only loop... and when I flashed it in a huawei flash tool, it displays BROM ERROR 6126.. which is the reason I got here, usually I didn't encounter this error before when this phone was bricked for the first time.. but now it really is crazy and there's no link on the internet that this BROM error 6126 was solved.. a lot of people is getting crazy about this error and no one knows how to fix, so the best way is to change the motherBoard.
Add a comment
Restarting Huawei
It is Flash Chip Problem''
Add a comment
This is hardware problem, if you can enter in recovery mode, it will work after software update. If you can not enter in recovery, try reflow eMMC chip. most cases is wather damege.
Add a comment
plzz help My Phone Restarts during Flashing :( :(
Add a comment
When I Uninstall what's app the problem is disappeared
Add a comment
got the same problem!
first i was using my googlechrome and suddenly it went auto restart
then everytime i open googlechrome it started to do auto restart
so i thought maybe my phone's memory is already full
so i tried to uninstall my other applications then restart my phone
after restarting my phone , all the applications that i uninstalled is still there
seriously uninstall the applications then its still there?
so i tried the factory reset.
i wipe all the datas and cache after that reboot system
still everything on my phones memory is still there
i even unchecked the auto restore backup yet nothings happened
how can i fix
Add a comment
my huawei y600 u20 logo appear than hanggin why?
Add a comment
Add your answer
Habib Ullah Qazi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 18,534
