Why is my Dremel is making loud squealing noises when in use?
When I use my Dremel it makes loud squealing noises, the faster it spins the louder it gets.
The bearings are dry and/or have run out.
I'm not sure about this model, but historically Dremel tools use bronze bearings. These are copper-colored rings that hold the shaft in place at both ends. They are slightly porous so they soak up oil. Over time they become dry.
Split the case to reveal the bearings. If they are ball bearings, they must be replaced. If they are bronze bearings as described above, and they are not worn because they've been left to run dry for too long, these can be lubricated with light machine oil. Use a fine nozzle to put a drop of oil where the shaft meets the bearing. Spin the shaft by hand, you'll see the bearing "sucking" the oil in. Repeat until the oil is no longer absorbed into the bearing, and clean excess with a cotton swab.
Reassemble your Dremel and let it run on low speed for a minute. If it runs silently, gradually turn up the speed. If all is well, it should run smoothly. If it still squeals, the bearings have been damaged and must be replaced.
The issue might be either the bearing are worn out or the brushes need replacement. Dremel advises changing the brushes every 60 hours of use. More information can be found at Dremel 4000 Troubleshooting.
Hi
You need to change the carbon brush to fix this issue.
what causes this t need replacement? mine isnt a dremel brand, but its the same issue. i havent gotten nearly 60 hours out of it yet. figures since it is another brand
Past 24 Hours: 0
Past 7 Days: 24
Past 30 Days: 115
All Time: 13,506
