Flashing Lights on Control Panel
Last night, I went to start my dishwasher. I pressed the Start button before noticing that I was on "Pots and Pans" instead of "Normal". I immediately pressed the "Cancel" button in order to change the cycle. I heard the drain cycle start and finish, then I saw the "Normal" button flashing. I could not select any other cycle, and got no reaction when pressing "Start". I pressed the "Cancel" button again, but it just started flashing as well as the "Normal" button. At this point, I flipped the circuit breaker off, counted to 10, and flipped it back on. This made the "Cancel" button stop flashing, but the "Normal" button kept flashing. I then checked the interior to make sure that the overfill cover moved freely, that the sprayers could all turn freely, and that the filters were clear. No change. I tried the reset procedures found elsewhere in this forum (alternately pressing "Heated Dry" and "Normal"; pressing any three buttons in sequence three times; and pressing and holding various buttons for three seconds each) with no success. The trouble shooting guide from Whirlpool does not address anything associated with flashing lights. I've left the door open and unlatched for 12 hours now with no change. Any suggestions that don't involve calling a repairman?
11 Comments
What everyone fails to tell you in these answers is....1. You can't reset it if the lights are on. Each time you hit the normal and heated dry, and it doesn't work, you're sending a signal to the control board to make another selection. Wait until all the lights are off, with the door open, press the "Normal" button, then "Heated Dry, and then do it again. Shut the door and all the lights will come on at once. It's reset then. Don't try and reset it with the "Pots and Pans" light on, just leave the door open and wait for the lights to go off. This means the control board has finished running through all the buttons that were pushed and it's waiting for a new signal.
by Kay Joyner
Well after replacing parts and doing the reset of normal / heat dry thing now my dishwasher lights come on but the start and resume light flashes what could be problem and how to fix please anyone
by Scott
Kay Joiner- Thank you!! Your answer was perfect- the tool I needed most was PATIENCE. I had tried the Heated Dry/Normal combo so many times
by madriverlauri
I have tried everything to reset the washer. took the board and unplugged it from the inside . nothing...still flashin lights "normal and cancel" HELP
by Rex Ferrell
What if it's the heated dry button itself that's flashing? I've tried everything. Even replaced the control board
by Puto Cracker
Show 6 more comments
