Repair guides and support for your Samsung TV.
2627 Questions View all
Why does my smart tv turn on and off overs and overs.
i turn it on and shows samsung smart tv then turns off quick, then on, then off, and repeats itself till i unplug it. it shows a that screen a second then repeats. what can be the problem and can i fix myself.
Score 33
49 Comments
kevin hernandez, what model # is your smart TV?
by
Un60es8000fxza is the model number.
by
Did you update the units firmware? If you didn't then go online and download the latest firmware to a USB thumbdrive and extract the software then plug it into the maintenance port of the TV and then turn on the TV. It should see the update as soon as it is turned on if not then see if you can navigate to the update menu and force it.
Luck!
by
Were would I go to get this firmware.
by
Went to the Samsung website but my model number don't come up.
by
Show 44 more comments
Add a comment
Chosen Solution
Go into Settings / System / AnyNet+
Turn OFF this setting fixed the problem for me.
Score 20
39 Comments:
How do you turn it off, if you can't get the tv to stay on?
by
Unplug the power, unplug network cable or network hub if in wifi. Leave for 10 minutes or so.
Turn it back on and no more blinking. Quickly go to Settings and turn off AnyNet+
by
Thank you so much!
It worked.
by
Awesome, I was ready to buy a new tv, not Samsung.
by
I has had this problem On/Off with Samsung TV, I want to fix it by myself before I throw it away. I go online and read the comments by Sua Truong to turn Anynet+. It works wonderfully. Now my TV is working like a brand new. Thanks Sua Truong
by
Show 34 more comments
Add a comment
The problem is caused by the TV auto downloading software updates and you allowing an upgrade while on a Wi Fi connection.
It must be on wired CAT 5 or better LAN CABLE back to your modem.
After it switches off and back on, it has now lost the Wi Fi password, so it keeps cycling off and on, as it cannot complete the set up with no Wi Fi.
I found that I had to go and deselect in the TV menu, to the get the IP details from 'automatically' to 'manual' to get out of the never ending loop of switch on and off.
My set was getting worse from once every 30 min to every minute, and it was not a soft turn off, but the audio was violently loud.
I have this happen several times over the years since 2012, and had banned at the modem from connecting to Samsung TV Software update. I had to factory reset the modem from another issue, but unfortunately an update slipped past me and onto the TV.
Nothing ever gets better from their updates, but causes trouble every time with simple things like HDMI no longer working.
What you need to enter into your modem 's 'blocked sites' as www.samsungotn.net
Then it cannot update the software, but the apps on the Smart Hub will update.
Some apps crash on update and cause similar issues, and if you have no internet connection, they will not cause so much a problem.
Score 6
15 Comments:
This worked for me, thank you!
by
I removed the wifi module. The turn on/turn off problem is gone! Other problems also went away. May not replace it, and just use ethernet.
by
We have a 49' LED UHD 4K TV when powered on it turns back off immediately...how do we fix this issue?
by
Mind went on and off and know it just clicks loudly. SAme problem?
by
This absolutely worked for me. Thanks rd013
by
Show 10 more comments
Add a comment
I have been having the same problem, I tried the above solution with memory card but wasn't able to get that to work, upon more research I found a post that said to remove the back cover, and unplug and replug the circuit boards, and anything that has a plug, and blow the dust out of the connections. Very easy as the post said, nothing that can really go wrong, the tV was useless. Low and behold, upon re installing the back and plugging in the set, for the first time in a month the set is working. Low tech, solution even I could do. Sorry for the neighborhood fix-it guy, he would have charged me 50 bucks just to diagnose it and Whatever part he thought I needed. I love the internet. Thanks to those that forged the road before us.
Score 4
2 Comments:
How can you do that if tv won't stay on
by
That’s what I said how can you do it if it doesn’t stay on
by
Add a comment
Check the remote https://youtu.be/2Jg7cMw2d18
Score 1
5 Comments:
I just got a Samsung tv today from my friend and all it does is turn on long enough to say Samsung and shuts right back off. I can't do anything. I've unplugged it for more then 15 minutes, switched outlets and all and that's all it does. I've always heard bad thing about Samsung products and I guess they were right.
by
Same problem here, think I've just wasted a lot of money.
by
I have the same problem
by
Anybody know what can I do to fix it
by
I had same issue here, turning off & off again & again. Can someone help? Have tried checking setting/system setup...all same am fed up kindly help, the TV is new I can't afford another for now.
by
Add a comment
So... I have been having the same problem for about 2 months and it just got worse. I opened the back like you said and cleaned all the connections 2 days ago. So far so good.
If this works.... I will give you all a million dollars.... When I win the lottery :)
Thanks guys....
Going to watch the Washington vs LasVegas game!
Score 1
Add a comment
turn off your wi-fi setting…sucks, i know since u purchased a smart tv for the web features but….at least you’ll have the basic tv function = watching tv without it turning off and on
Score 1
Add a comment
The problem is not in the Wi-Fi module, Just in power consumption. In my opinion you can freely put Wi-Fi back in, remove the cord between mainboard and power supply board, turn it around, then plug again. You will see that one vein will be a little bit darker in plug. That because Samsung picks too thin to deliver so much energy to mainboard.
Score 1
1 Comment:
My Samsung smart tv working when I use my mobile hot spot but when I use broadband wireless the tv switch off and on continuously .
Please anybody solve this issue
by
Add a comment
http://www.samsung.com/us/support/owners...
1 Comment:
I have a tcl roku tv when i turn on a blue screen come on then a turn off after that what can it be it doesn't she a picture at all it was working fine now it stop what can it be help pls
by
Add a comment
Hi All,
Even I had this problem, My TV was getting repeatedly getting turned off and on. I went through many blogs and forums, but couldnt get any satisfying answers.
I thought lets do something on my own, I removed the back panel of the TV cleared some dust and then unplugged and replugged all the cables inside the TV, Fortunately it resolved my issue and now the TV is running awesome like never before.
3 Comments:
My samsung plazma tv model no mqwc3pcd403035 tv autometicaly off
by
The only clicking (on/off) reason is not enough energy on mainboard. Most often it is enough to reverse the cable between the board and the power supply, sometimes it needs to be replaced. It is rare to replace the power supply board.
All tips to turn off WIFI, BLUETOOTH, ANYNET + etc. works if, after disconnecting a particular circuit, there is enough current to handle the rest. The problem hides in the cord - it is poorly designed. New, original cable costs 30 €. It may be exchanged even by a child.
by
Hello, How do you get in the menu if the tv keeps turning on and off non stop.
by
Add a comment
Same issue of turning off and on randomly. 5 year old Samsung 46" smart TV was not connecting wirelessly. I hooked up via ethernet cable, no updates needed. At this point, I assumed it was the wireless LAN that was corrupt after some reading and the fact it would dump out of the wireless setup menu when I tried to connect. I unplugged the wireless LAN, both back panels had to come off. It was tucked up under the outside plastic back panel on bottom left side looking at back . One screw and unplug, simple clip to unplug. Essentially made it a dumb TV. I use wireless Roku box (prefer that over 2011 smart hub) to make it smart again. So far so good.
1 Comment:
by
Add a comment
Just change the cord between power board and main board :)
Btw - main board is not as expensive as You think ;-)
Add a comment
Removed wireless LAN. Bought a Roku. TV has not been turning off and on since.
Add a comment
Change remote batteries. Problem solved.
Low battery sent off on signal non stop. We tried everything ——
55” Samsung Smart TV
Changed remote batteries —- it fixed problem. Now it doesn't spaz infrared signal telling tv to turn off.
1 Comment:
Is the problem still gone?
by
Add a comment
This is a VERY common concern in late model large flat screen televisions. The mounting screws on the main board become loose over time due to vibrations from the speakers as well as lower torque values during the assembly process. The easiest way to diagnose if this is your condition is to increase the volume while the TV stays on for more than a few seconds. If by simply raising the volume the TV turns off (and may start cycling on/off) you probably nailed it. Power down, allow several minutes for the capacitors to discharge then remove the back cover, remove each circuit board one at a time. Using a small wire brush or sandpaper, clean the areas that the board makes contact with the frame, where the screws thread in. Install the circuit board a d tighten the screws firmly BY HAND. Repeat throughout and watch your annoying issue become a thing of the past.
1 Comment:
It won’t stay on long enough to increase volume to troubleshoot
by
Add a comment
If the TV has been connected to the internet then disconnect the LAN cable and disable wireless LAN and do a factory reset details of how to do this should be in the handbook that came with the TV Set and that should solve the problem, if not then you will have to remove the back panel and disconnect the connecting lead that connects to the surround near the bottom left and replace the back panel, don’t worry you can still control the TV via the remote control, the reason that this happens is that you get a build up of grease and dirt on the contact area of the TV controls on the bottom right of the set.
Add a comment
Have a Toshiba smart TV 4 years old with same on and off problem.changed remote battery didn't work but then I unplugged the TV from wall waited about a minute plugged back in and it worked. I also have to do the same thing to a LG washer. I think you need to reset the electronics on these devices from time to time.
Add a comment
As I wrote many times, the problem is insufficient power on mainbboard. Problem appears after few years. Ask someone with screw driver for help, open the back cover of TV set, disassemble the cord with many veins between two big boards, then plug it again in opposite direction (plugs are same).
You just saved few hundreds :)
2 Comments:
Thanks, do you know of any video or guide which can be followed and I can do it myself. Really appreciate your help.
by
There is a eprom IC needs replacing and re programmed it needs special tools to remove check on ebay there is a guy who can do it
by
Add a comment
The 1st time this happened to me , I simply changed the batteries and all was good .6 months later this happened again and was recommended to try holding down the ‘back’ button and the volume ‘up’ button at the same time for 10-20 seconds , this has corrected the problem .Time will tell if this issue is resolved .
Add a comment
https://www.youtube.com/watch?v=bJ8HSLlO...
1 Comment:
Most fixes didn't work for me - then this video gave me an answer and allowed me to freeze a nand chip and give me enough time to install software updates
by
Add a comment
I removed the back cover, attached to it is the WIFI module. I unplugged it and no more problems with on/off issue. We’ve had to use the Ethernet port for most of the time sense we bought the tv. So I suspected there might be a comm issue. I guess the module finally crapped. Here is the part number for those who might want it.
UN40EH5300 Wi-Fi Module BN59-01148A
Add a comment
This issue has been bothering me for few years, now it can be easily fixed. Manty thanks rd013 and Stephen Stragnell for your great contributions to the community.
As rd013 pointed out, the problem was related to the firmware upgrade and wifi password loss.
I followed the instructions from Stephen: remove the back cover, and unplug and replug the circuit boards, and anything that has a plug, and blow the dust out of the connections. The firmware went back to its original version after those steps and the tv could stay on. I then turned off the auto upgrade and blocked www.samsungotn.net from the router.
1 Comment:
Why does my samsung tv turns off and on
by
Add a comment
Add your answer
kevin hernandez will be eternally grateful.
Past 24 Hours: 20
Past 7 Days: 115
Past 30 Days: 608
All Time: 375,956
