Released June 2014, identified by model number B051.
33 Questions View all
How to put black leather around beats headphones
The leather on my Beats By Dre Solo2s are coming off. It is not the actual ear cushion though that is falling off. It is basically tucked in under the ear cup. Is there any way to re tuck it underneath the earcup?
Thanks for your advice
Score 17
41 Comments
How would one go about re-gluing the ear cushion? The leather on my ear cushion has separated at the seem on the inner-perimeter of the ear pad (you can see the edge where it is 2 separate pieces of leather bound together). Any suggestions would be a great help!
by
You can use a credit card to push it back into the groove it's come out from. Works perfectly
by
This worked perfectly for me. Thanks!
by
Great solve. Thanks!
by
You saved me!! Thank you!!
by
Show 36 more comments
Add a comment
Chosen Solution
If you still have this problem, just grab a debit card or any kind of card as long as the card is strong and will not rip/break on you, and just tuck the leather into the "slot"
I personally do not like to damage the device by adding glue because adding things can ruin the headset itself so I would rather have to re tuck and have the headset good as new than use other items and ruin it.
Score 52
31 Comments:
This was so helpful, thank you!!!
by
worked like a charm. i was so worried I'd have to waste time going into apple store. thanks!
by
this was so helpful thanks! i used a gift card which was a little thinner and easier than a credit car
by
Follow Mike's advice above to use a card!!
by
by
Show 26 more comments
Add a comment
Completely remove the cushion from the headset. Then squeeze foam add super glue to the edges, put edge of leather to the super glue, then hold it or tape it down till the glue sets.
Score 2
1 Comment:
If you don't want to use glue, look at Mike's response!
by
Add a comment
The Credit Card is a good temporary hold for the slowing drifting leather but if you want a permeant fix id advise watching this video, i did and followed the advice and now my beats look impeccable.https://www.youtube.com/watch?v=o57sTtr8...
Add a comment
use any type of card but has to be strong enough not to snap just push the ear pad back into the headphone with the card
1 Comment:
Tucking works but not for long. Very disappointed in quality of such an expensive set of headphones.
by
Add a comment
Are there any new cushioning than can be purchased to replace the existing one’s? I pushed it back but it’s temporary and it keeps coming out and it looks tacky
Add a comment
Follow the instructions from this video
https://youtu.be/mVTXCghufV4
Add a comment
I suggest you to buy ear pads replacement for beats headphones from beatskin store because you will get a detailed tutorial on how to replace them and a repair kit too. Here you will find ear pads for any beats headphone model https://beatskinstore.com/product-catego...
Add a comment
Add your answer
zaydnavaz will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 35
All Time: 136,394
