The third-generation Ram was unveiled on February 7, 2001 at the 2001 Chicago Auto Show. This was a major update including an all new frame, suspension, powertrains, interiors, and sheet metal.
81 Questions View all
Why does my heater/air conditioning blower just work sometimes?
When I turn the blower switch on, sometimes it works other times it does not, when it works it works correctly on all speeds, when it does not, nothing comes on.
Score 1
Add a comment
1 Answer
Chosen Solution
Randy, Intermittent blower motor problems, try moving/wiggling the key around with ignition on to see if that effects the blower motor, if it does the ignition contacts/wire could be bad. Other problems could be the blower motor resistor(common problem) or blower motor itself, the switch could be the problem but not common as others.
Score 1
Add a comment
Add your answer
Randy Wilson will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 14
Past 30 Days: 57
All Time: 7,136
