Repair guides and support for Saturn's 2nd generation SC, SL, and SW.
19 Questions View all
Fuel not getting to the engine
My 1999 Saturn SL1 stalled while I was driving a few times and each time I would have to wait while before it would start again then the day came it stalled then never started again.
I replaced the Electric Fuel Pump, Fuel Filter, Electric Fuel Pump Relay, Battery and cleaned the Carburetor.
Still won't start, so a friend and I tried Starter Fluid Spray. It did a rough start and idle as long as he would spray then stall when he stop. It would not start on its own only with the spray.
So we're stuck. No Fuel Getting To Engine. Please help us.
Doing everything old school way, other then the internet.
2 Comments
leggs367 you said you "cleaned the Carburetor" the Saturn uses TBI and not a carb unless this was somehow converted. Have you checked the crankshaft position sensor ? Of course you did check the fuses.....ECTS are a common failure on this model. something to look into
by
Try checking the fuel pressure sensor as well. Mine done the same thing
by
Add a comment
Chosen Solution
leggs, Check to see if there are any trouble codes that may help in diagnosing no start condition. Was the correct fuel pump installed, was it a complete fuel pump assy. or just a pump and installed correctly? Is the new fuel pump coming on, have an assistant turn ignition to on position while you listen for pump humming at back of car with gas cap off. You should here fuel pump hum or buzz for 3 to 5 sec's as it builds pressure, check for correct pressure at the fuel rail 45-50 psi, if you do not hear pump, faulty fuse, relay, wire/plug/ ground corroded damaged, fuel pressure regulator(filter), bad pump, crank sensor, ECM,. Check the attached links,instruction and guides, Good luck
https://www.youtube.com/watch?v=lqlBWRMw...
https://www.youtube.com/watch?v=uo5OeHcv...
https://www.youtube.com/watch?v=tJF5Lli4...
Score 1
Add a comment
1st , check if there is fuel on fuel line , I believe your car has injector(s), check for power and ground on the injector wires , one of those wire will be the control side which will flash as you crank the motor. might be a good idea to check your fuel injetion fuse and relay.
1 Comment:
Hey I put a new fuel pump on my car went and put gas in it and it wouldn’t start back
by
Add a comment
If everything else mentioned here fails, there is another potential problem: WATER. Now that fuel has higher ethanol percentage, it attracts water. Sometimes there is so much water in the tank that the fuel pump doesn't actually pick up any fuel, but only water. Obviously a car cannot run on water. Simple solution - drain the gas tank.
Add a comment
i have a 1991 saturn have same problem i have a good fuel pump and am not getting pressure to the injection rail dropped tank checked pump and checked for debris or water, checkewd fuel filter, i have no clue why theres no pressure
1 Comment:
What did u find
by
Add a comment
Well, what was it in the end? Having the same issue.
Add a comment
Add your answer
leggs367 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 38
All Time: 10,428
