Repair guides and support for Whirlpool brand dryers.
27 Questions View all
Why will my dryer only dry one load of clothes a day?
My whirlpool duet dryer will dry one load of clothes then needs to be unplugged for a day before it will dry another load. The clothes are so hot i have to let them sit for a while before folding. I did the diagnostic and i get the 88 with all lights on. I then rubbed my fingers over the sensor on the lint box and got a code of 09. I am not sure what is wrong with it. Any help would be greatly appreciated. Thank you
Score 1
Add a comment
Chosen Solution
isaksmama sounds like the dryer is overheating. Could be an issue with the cycling thermostat (thermistor depending on the model) or the high-limit thermostat. It overheats and will not turn on until it cools down would be the result. Let us know what the exact model of your dryer is so we can try and find more concise information.
This should work for your dryer
Score 1
4 Comments:
mod: gew9250pl0
ser: ms2516987
type: dadt ele 2406028 el54
by
@mayer what do you think? I believe that isaksmama can pull this off. Just consider taking lots of pictures and posting those with your question in case you get stuck. Use this guide Adding images to an existing question for that.
by
You guys are great. I will definitely take pictures as i go. After all i am going to have to put it back together again.
by
That's the spirit :-) let us know how it works out. If you use the @mayer or @oldturkey we get notified that there is a new comment to this question.
by
Add a comment
Most Helpful Answer
Code 88 is a diagnostic mode code
09 is a thermal cut off
Most Frequent Causes for Dryer overheating
Cause 1
Heating Element
The heating element warms the air before the air enters the dryer drum. If the element is partially shorted out, it may produce heat continuously, even if the dryer has reached the proper temperature. When this happens, the dryer gets too hot. To determine if the heating element is at fault, use a multimeter to test each terminal for continuity to the case. If the heating element has continuity to the case, it is shorted out. If the heating element is shorted out, replace it.
Cause 2
Heating Element Assembly
The heating element warms air as it passes over the element. If the element is partially shorted out, it may produce heat continuously, even if the dryer has reached the proper temperature. When this happens, the dryer gets too hot. To determine if the heating element is at fault, first use a multimeter to test the heating element for continuity. If the heating element does not have continuity, replace it. Next, test for continuity from each terminal to the case. If the heating element has continuity to the case, it is shorted out. If the heating element is shorted out, replace it.
Cause 3
Air Flow Problem
If the vent is clogged or partially clogged, it will restrict the airflow through the dryer, substantially increasing the drying time. To ensure proper dryer performance, you should clean your dryer’s venting system at least once per year.
Score 2
1 Comment:
Thank you for being so detailed in your response. Is this something that i would be able to do myself? I am not very mechanicaly inclined.
by
Add a comment
Add your answer
isaksmama will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 20
All Time: 1,897
