The square button is not work
The square button when I press on button is not work what I do
Hi Amjad!
You can find our repair guides here for fixing or replacing the buttons on this controller:
DualShock 4 (CUH-ZCT1U) Buttons Replacement
We also sell replacement parts for the controller if you need them. These are the buttons:
Make sure to clean the connection to from the conductive film to the motherboard.
Thanks on the bottom of the phones keyboard, the square button doesn't work. How do I get it back working?
How to make this work
I was having issues with my left analog stick constantly drifting. Took the controller apart and cleaned it. Now it works great……except the square button doesn't work now. I'm thinking it's the clear film. May have a tear but I can't tell. Hope that info helps someone. Still working on my square button. Thinking about buying another mother board.
I did same thing as Jason above, took controller apart cleaned it thoroughly put back together and square button not working.
Exact same thing happened to me cleaned joysticks sensors and now square button doesn’t respond, I can see and feel it makes contact but no response I was thinking it was the ribbon strip because a couple of connections on the ribbon were folded back from disconnecting and reconnecting so many times maybe this could be the issue?
Past 24 Hours: 2
Past 7 Days: 26
Past 30 Days: 121
All Time: 84,943
2 Comments
you can replace the square button. you can order the motherboard from the IFIXIT site. and you can see how to fix also on this site.
by Keegan Bourque
Yo no lie all I just did was get some scissors and pull up tried to wedge it in the side and just keep doing that trying to take the square button out than just pull up Spotify and keep trying use square till it work I swear try it
by Breeyon
