Support for musical holiday decorations by Mr. Christmas Inc.
71 Questions View all
21 Christmas carols stopped playing
Mr Christmas Holiday Merry-Go-Round
Merry-Go-Round turns, horses go up and down, light turn on but there is no sound. 21 carols are supposed to play. I have the volume turned up on high. Received from a friend. Any help out there??
Score 2
Add a comment
1 Answer
Chosen Solution
Try to unscrew the roof, if it doesn't feel like the screw is raising up - stop turning as the shaft it is screwed to is also turning and this will twist the roof lights power wire inside the central shaft and rip the connection off the land on the circuit board below. This will also stop the motor supply. If you gently insert a wedge between the outer rim of the roof (push in that side's retaining tab), you can insert a pair of long nose pliers in and grip the central shaft, then you unscrew the top screw and remove the roof. Now you can look for broken wires.
Score 3
3 Comments:
No broken wires??
by
I meant, there were no broken wires...anything else to look for?
by
Use a multimeter to test if you are getting any power to the speakers. Continue to test for continuity down to the output source.
by
Add a comment
Add your answer
K Marschel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 2,177
