The Sky Viper v950HD Video Drone comes with a high-definition SkyPro Camera made to capture bird's eye view video footage in crisp 720p HD. Released mid to late 2015.
9 Questions View all
My sky viper drone wont fly
My stunt drones controller comes on and beeps, when I plug up the drone the light go from flashing fast to a lil slower but my controller still beeps. Ive messed with the throttle and even left it on for a while. After about 5 mins the controller stops beeping but won't fly, it plays a weird tune when I press a button.
Score 15
31 Comments
Sound like mine im thinking time to return it
by
Mine doing the same thing so I'm recharging the battery to see if it's just a dead battery. If so, they don't last very long.
by
Mine is all the sudden blowing air upwards basicly pushing itself down instead of picking it's self up does anyone know how this is possible all I did was recharge the battery and that's cool proof it's a one way connection
by
I'm having the same problem with my sky viper stunt drone 01599 I can't find how to fix anywhere on the internet
by
my props spin but only half the drone picks up (it tilts)
by
Show 26 more comments
Add a comment
Chosen Solution
Make sure the throttle (left stick) is all the way down. It's possible you got one with a bad board. Try and move the throttle stick all the way up and then all the way down. You need to do that if you turn the controller on with the throttle in the mid position. If that doesn't work I would suggest returning it for a replacement.
Score 6
10 Comments:
I have tried this it still doesn't work and I'm not returning it.
by
My battery is not working I so I plugged it in the drone would work
by
i kind of have the same thing i got my skyviper V2450 2 days ago for christmas its been flying good until the next morning i turn it on and i move the throttle but it wont fly i did that five times and i cant find the wifi in my phone
by
I had the same problem. What I did was hold the land and sport button simultaneously and that resolved the issue
by
Itttt don’t work :( and I’ve only have had it for about two years
by
Show 5 more comments
Add a comment
The drone battery only lasts about 15 minutes or so. Once the battery is drained, the controller beeps and the drone won’t fly. The solution is to plug in the rechargeable drone battery to charge it back up.
Score 3
3 Comments:
My Viper v2900 pro is not working two of the motors will not turn when powered, but turn as freely as the others with no power
by
Same here but only one motor not activating. Brand new Straight out of the box & couldn't fly it after all the setup & charging. Had some friends come up to see it & it's a complete fail.
by
I called the support number and no one answered, more then once. Never did get an answer
by
Add a comment
Connect your controller to the drone,when the lights on the drone go at a steady color you can then fly it.
Ps. You connect the controller by turning it on put it by the drone and wait
Score 2
1 Comment:
My Was Doing The Same Thing I Ran Calibrations And It Flew After I Power Cycled It
by
Add a comment
I was having the same issue today. Had batteries in the controller from before Christmas (not left in the controller) but still questionable. Works for a minute or 2 then beeps again and I have no control. Drone battery is fully charged. I changed the controller batteries with what I thought were new batteries. Worked great for about 5 or 10 minutes, then beeping again. Going to get some brand new batteries for the controller and see what happens but my guess is that's it.
Score 1
1 Comment:
I just went and but brand new batteries in my controller blinks and beeps still
by
Add a comment
My drone was awesome until one of the motors stopped working. I bought a replacement motor on eBay and started flying it again. But, now it won't connect to GPS and will only fly in indoor mode. It plays the same weird tune you're talking about. I'm going to update firmware and see what happens.
Score 1
1 Comment:
Where are the motors located ?
by
Add a comment
Score 1
3 Comments:
what sport button
by
I’m confused there is no sport button I think u mean stunt button
by
No there is a Normal and a sport button together on the lower right side
by
Add a comment
The beeping your most likely hearing is when its recording video..
2 Comments:
On the controller
by
My drone normal and sport is lightning
by
Add a comment
My drone back left Has a wire dis connected need help pls
Add a comment
just got the journey pro yesterday put the battery in was working great I charged the battery now gps reads good to go its all connected but the drone wont start video works but motor wont run
1 Comment:
connect to the skyviper video viewer 2.0 app and see what it says. had to calibrate mine b4 it would do anything.
by
Add a comment
Mine turns on right. It flashes lights it connects to the controller it starts to turn the propellers and then it disconnects and controller continues to beep… Any suggestions please???
1 Comment:
In settings I put it on slow and it finally lauched
Now need to recalibrate
by
Add a comment
My son bought the Sky Viper Dash Nano Drone at Target last night. Charged the drone and put new batteries in the controller this morning.
So far it doesn’t work. The flight mode button on the controller blinks back and forth between Normal and Sport.
Any ideas how to fix this?
2 Comments:
Did u ever figure it out cuz I'm having the same problem
by
Me to I’m clueless
by
Add a comment
My friends son has one and when they try to connect the wifi to it, it say internet without connection where the ! is one the wifi signal area. The controller keeps beeping on the lock and unlock lights. We can't figure out how to get it to connect. Can someone help me?
Add a comment
Add your answer
Danney Stipes will be eternally grateful.
Past 24 Hours: 14
Past 7 Days: 93
Past 30 Days: 434
All Time: 86,836
