Repair guides and support for iRulu tablets.
133 Questions View all
Why wont my tablet work unless plugged into charger
My tablet wont work at all unless it is plugged into the charger even though it has been charging over night. It keeps saying connect to the charger even though it is plugged in already, what should i do to fix it
Score 1
2 Comments
Hi,
What is the model number of your tablet?
by
the model number is AX922
by
Add a comment
1 Answer
Chosen Solution
Hi,
It seems as though the battery is failing to hold its charge and needs to be replaced. Even rechargeable batteries have a life span.
Unfortunately as I cannot find a guide on how to open the tablet to gain access to the battery, I'm hoping that this guide on how to replace the battery in an Irulu ax106 will be very similar to your model and will be of some help.
iRULU AX106 Battery Replacement
Here is a link to a supplier of a replacement battery for your tablet. It is not a recommendation to use them, it is shown just to give an idea of the price of the battery. there are other suppliers that may suit you better. Just search for Irulu ax922 battery for results.
http://www.actablet.com/replacement-4000...
Hopefully thisi sof some help.
Score 1
Add a comment
Add your answer
laurabooth4 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 1,508
