How to set timing marks
How do I set the timing markings on my 2006 Hyundai Tucson 2.7L V6 2WD.
This is a tear down video that's pretty detailed its for a Santa fe but the motor placement and assembly are similar the Tucson
https://www.youtube.com/watch?v=rZ2rtr5-...
This guide may also prove helpful
http://www.hyundai-forums.com/sm-2001-20...
and finally what to look for when aligning the marks
http://thumbs.ebaystatic.com/images/g/r~...
Hope this helps
@lndramirez, Lupe Ramitez , Both links are pretty good at showing the timing line up marks for Hyundai Delta 2.7l V6 engine found in your Tucson. The 2nd link goes through the procedure pretty much step by step with pic's. Good luck.
@lndramirez it would take a while to formulate an answer for you on here. I suggest that, for a great write up on this, check on here.
@oldturkey03 @lpfaff1 Well guys I think we answered the daylights out of this one .I wonder if they'll come back to see
@jimfixer , @oldturkey03 , Yep. sometime's, I could be researching or writing/editing on an answer, go to post and it has been answered 3X.
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 55
All Time: 8,121
1 Comment
I can't seem to be able to get the what to look for when aligning timing marks. I've done it all set all marks. It just won't start, #1 piston at the top, timing marks inside heads match up all marks end up at set point after I hand rotate 4 revolutions. Don't know what else to do.
by Jimmy Madrid Jr
