Repair guides and support for Panasonic's Viera line of televisions.
418 Questions View all
Why does my Panasonic LCD TV turn itself off after 2 seconds
My Panasonic Viera tv keeps switching itself off after a couple of seconds.
The model type is TX-58AX802B. I have tried unplugging it and holding the on button as suggested on other answers but with no success. Can anyone help?
Score 10
16 Comments
@bone1 whenb you say turn off do you mean it shuts off like a no power situation? Besides the reset with the power button, what have you checked?
by
Hi .. i have a panasonic led 50inches Tv. When it is switches on i will have on off image fir about 10seconds..and then the green led will blinking rapidly and turned off with steady red led. anybody have any idea?
Thank you..
by
I have the same problem.. can anyone please answer this.
by
I’m having this problem too
by
by
Show 11 more comments
Add a comment
Chosen Solution
I had the same problem and fixed it. In my case my older TV had dust stuck in the fans. I disconnected the TV, took it down from the wall, placed it face down. Instead of unscrewing the many many screws (some of which were stripped), I took a hair dryer and blew air on the top vents with the fans below. Dust and dirt blew out. I did this for 3 minutes/fan until no more dust came out. The replaced the TV on the wall, reattached cables and voila it works and does not shut itself off
Richard
Score 14
16 Comments:
Yes thanks Richard, I just followed your instructions with the hair dryer on cold. It works again and does not turn itself off. All fixed. Fantastic
Gav
by
My 42 inch Panasonic shuts off after being on from an hour or the whole day. When it's off I can only turn it in at the TV, hold the button down either for a few minutes or seconds. Depends, and it'll come back on. Do you have any idea? Appreciate! Peace!
by
Richard you are my hero. Took it to my workshop and blasted out with compressor and so far works just as did before. Was inch away from buying replacement . Cannot thank you enough for advice makes me wonder how many tv chucked away and how much money wasted on rip off ‘repairs’ due to this . Thanks again
by
Richard Wolf thank you so much, I did same thing with the dryer it works, thank you than you thank you.
by
Omg!!! It worked thank you guys
by
Add a comment
@bone1 it does sounds like a power board issue. You do want to remove the back of your TV set and take a look at the board. Check for leaking and/or domed looking caps or anything unusual. Post some images of your boards with your question. Use this guide for that. It will allow us to see what you see.
Before anything else, please double check the warranty status on this set. It is really not that old and may still be covered.
Score 5
7 Comments:
If it is this, can it be fixed or do you need a new board? I have the same issue
by
@noideawithtech either repaired or replaced. It will depend on what exactly has failed. If you let us know the exact make and model of your TV and what the issues are with it, we may have a better answer for you.
by
TX-55AS740B. Hi my Panasonic tv stays on for 1 second and switches off. Can any one help why.
by
I have the same problem the make of the TV is TC-50S2 Panasonic can anyone help out on this issue I am gonna blow the fans and back of the TV to see if dust jammed the fans and that's why it's shutting itself off and wait to see if someone else has a suggestion or a fix ! Thank you for any reply's to this fix.
by
@Jose Arellano have you cleaned the fans yet? what are the results?
by
Show 2 more comments
Add a comment
Panasonic Viera. Model number: TX-50CX700B
just switches off randomly with the flashing red LED every 5 seconds. There`s no pattern to it, it can do it 5 times in a few minutes or stay on for a week or more. At the weekend I took off the back panel and cleaned all the dust out of it thinking perhaps it was a build up causing a heat issue, still the same fault.
2 Comments:
@te8yinaihyl5y7o somehow your question ended up as an answer to an old question. It got lost :-( anyhow. Did you get this fixed? You still working on it or did you properly dispose of it?
by
Nope. Eventually I sold it for £10 to a gamer and bought a new 55 inch Hisense
by
Add a comment
Add your answer
Andrew will be eternally grateful.
Past 24 Hours: 11
Past 7 Days: 93
Past 30 Days: 606
All Time: 97,822
