miata wil not start with clutch depressed
new battery, all other electrical elements functioning, clutch depressed, starter will not engage.
Hi,
There are two clutch switches.
The big white one which is engaged only when the pedal is fully depressed is a starter interlock.
Not sure if this is the same for your year model but hopefully it is of some help.
http://blog.miataracer.com/2012/06/how-t...
There's a smaller one, up under the dash, which disengages when the pedal is slightly depressed. This goes to the cruise control unit as well as to ECU pin 1V. In a M/T car it's a brown-white wire. This wire is also connected to the transmission neutral switch.
thank you...where is the white starter interlock located?
Hi @mikemiata ,
It might have changed colour. Is there not one where it is shown in the picture in the link that I posted?
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 1,665
1 Comment
is there a electrical relay on clutch pedal that controls the start function?
by michael lutsic
