A Color Document Scanner by Epson.
3 Questions View all
Jams when scanning Drivers License
We use the DS 510 in our medical office. The scanner used to scan both Insurance cards and photo ID's with no problem, but recently it jams on only the Drivers License photo ID. I have looked and found no mechanical issues. If we place the ID longways in the scanner it will scan, but then we spend extra time rotating the ID for our files. Time consuming. Any suggestions?
Things I have tried:
Adding post it to the back side of the ID - still jams
Moving the mult page and cont feed button - still jams
Add a comment
Most Helpful Answer
I ran into this too. There's a setting that can detect double-feed (thick document) situations. When the setting is on, cards I scan will jam. If I turn it off, I can scan cards. Good luck!
Score 2
1 Comment:
This fixed it. I created another preset job titled Card Scan Double Sided. I followed the configuration as shown above from Ed. Worked perfectly. Thanks Ed
by
Add a comment
Thicker or stiffer stock of the ID's maybe the issue, the unit may not have been designed to feed it.
The other possibility is the motor drive is getting tired or worn, can you try out a second less used unit?
1 Comment:
Could it be a security measure to stop people from creating fake IDs? Ive heard they have a way of doing this with cash notes.
by
Add a comment
Have you looked at you scanner software to see if you can rotate the image after scanning and before saving?
R
Add a comment
We have this same issue with a DS-530 Scanner. The manual states to place the card horizontal and not vertical. However, the same manual also states that the card thickness capacity is .050” but the cards that get stuck are only .027”, measured with a micrometer caliper. I have opened a ticket with Epson for this.
Add a comment
I have noticed this for the new TX driver licenses that have an engraving. You can feel it with your hand. The old ones that are smooth are still working fine
Add a comment
If you put your hand in first and push the feed rollers (the ones closest to you) you'll feel them adapt (for thicker documents I understand). Then put the ID in (and align the guides. It should feed it through just fine.
Add a comment
Add your answer
Shannon Freeman LAC will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 15
Past 30 Days: 128
All Time: 4,024
