It was a six-wheeled tank with a front-mounted blue photon beam headlamp, and a keypad on top.
6 Questions View all
Elicits unending tone when GO is pressed
I used fresh batteries on a Big Trak, early 1980's model, which had not been used in more than two decades. After I program Big Trak, I press GO and all it does is elicit an unending, loud tone. I presume it is "stuck" somewhere. Who can repair this vehicle, if it is worthwhile or possible to repair?
1 Comment:
Did you check to be sure the 9-volt is at 9 volts. Mine was at 8 and it was doing that exact thing. I am doing a once over before I put it up on e-bay, Mine is gray though. And I have the transport too.
by
Add a comment
1 Answer
sounds like the motors are stalled.
I would work the drive wheels back and forth by hand and see if that frees it up. Also make sure ALL the batteries are fresh. These are real battery hogs.
Add a comment
Add your answer
Gary Tameling will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 243
