Repair guides and support for top and front loading Whirlpool brand washers.
427 Questions View all
Washer filled with water then stopped working
I have a Whirlpool washer/dryer combo in which the washer has stopped working. This happened earlier today. I checked and the dryer still runs. I have unplugged the unit from the wall for a minute and also opened/closed the lid multiple times within a few seconds and that hasn't reset it or anything. I am not sure where in the cycle the washer stopped because I didn't pay attention to the knob before trying to figure out what was wrong with it, but the washer is full of water. I bailed out about 1/3 of the water and tried to 'reset' the cycle to see if it would start to fill up with water again but it still did nothing.
I should probably note that I recently bought some new towels that seem to have shed quite a bit in the dryer (the lint screen was plum full) but I figured if the washer was trying to drain it would at least make some sort of noise.
Any help would be appreciated. I would really like to get this fixed rather than go through the process of buying a new setup.
Score 2
11 Comments
@eatsleepindie does it drain when you move the timer? what exact model is it? If it does not drain but everything else functions i.e. agitator moves program timer advances but washer does not drain, I would suspect an issue with the pump.
by
The water does not drain regardless of where I put the timer. In fact now nothing happens in any of the timer positions. It's an old model so I'm not sure if simply turning the timer to a specific position should start the agitator or start it draining, but neither works. So far I've figured it was the timer itself or the lid switch, but if you think it is the pump then I'll likely order a new one. Is there a way I can test to make certain the pump is the issue?
by
It's a Whirlpool 'Thin Twin'. Definitely an older appliance, came with the house but I'd much rather fix it than but a new one if possible.
by
Same thing happened to me today! What was the problem? What was your solution?
by
@eatsleepindie check your lid switch first.
by
Show 6 more comments
Add a comment
Most Helpful Answer
Cause 1
Drain Pump
Sometimes, small objects or articles of clothing can get caught in the drain pump. To determine if anything is blocking the drain pump, remove the drain pump and check the pump for obstructions. If the drain pump is clear of obstructions, but is still noisy during the drain cycle, replace the drain pump.
Cause 2
Clogged Pump or Hose
Sometimes, socks and other small articles of clothing can get into the drain system and clog the pump hose or the pump itself. Remove the hoses from the pump and check for any obstructions.
Cause 3
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not drain. To determine if the lid switch assembly is defective, use a multimeter to test each of the lid switches for continuity. If a lid switch does not have continuity, replace it.
Score 4
10 Comments:
Mines full of water n clothes he made a noise i opening it n close it just made a humming noise then stop what is it
by
@teresa41 most likely cause 1 or 2
by
@teresa41 check your lid switch
by
Teresa, mine did the same thing. What did you determine was the issue with yours?
by
Wow, I wouldn't have believed it, but my sister was having the same problem and I had her slam the lid and it started working!!
by
Show 5 more comments
Add a comment
Hey Al.
Have you checked to make sure the outlet the washer plugs into has power? Is it possible that the circuit breaker was tripped?
Score 1
1 Comment:
Also Al, really would be helpful if you'd include the washer model number, as several members have previously suggested.
by
Add a comment
I have a Whirlpool "Thin Twin" as well, and mine just had it's 14th birthday. The agitator would not spin despite the the unit receiving power. The drum filled with water, and the dryer operates just fine. I decided to pull out the lid switch. Very easy to do with a phillips screwdriver. I discovered that the amount of travel required to activate the switch increased to a point where the plastic tab on the lid couldn't press it enough to activate the switch. The switch itself was starting to come apart... it is two plastic halves that join together with a type of seal. Not sure what was causing the two halves to lose the ability to hold the switch unit tightly together... but I solved the issue by using a plastic zip tie to fasten the unit together tightly. Now the plastic tab on the washer lid can actuate the switch lever.
Score 1
Add a comment
I have had this exact same problem with my Whirlpool. Not sure if yours is a top loader like mine, but I found that slamming the lid would get it going. Then my husband discovered that there was a screw on the side of the lid that was loose. Not sure how a loose screw on the side of the lid prevents it from starting to agitate, but once he tightened it, the washer worked fine. No more lid slamming. Lol
Add a comment
I can’t believe it but I read this because my whirlpool was not working and I also slammed the lid and it started working. Once it finishes, I will see if there are any screws to tighten it.
1 Comment:
Wow i just slammed my lid and nothing but fooled around underneath the lid in the back and then slammed it again as hard as i could and what do you know...it started working again...thanks so much everyone atleast i know its something minor and the whole thing not blown up...mine is older and i HATE these new washers they have now that puts less than an inch of water in the tub and that is supposed to clean your clothes ..no thank you!!!
by
Add a comment
I put a ruler into the slot for the washer lid switch& pushed it up & down. Solved the problem.
Add a comment
Add your answer
Al Ridley will be eternally grateful.
Past 24 Hours: 16
Past 7 Days: 205
Past 30 Days: 1,005
All Time: 90,871
