A basic battery-powered rotary tool Manufactured in 2007 by Dremel.
4 Questions View all
Spanner broken and stuck on dremel
My dremel spanner is stuck inside the dremel. How do I remove the broken piece so i can replace it so it will grip the bit again when I tighten the collet nut on?
Add a comment
1 Answer
Most Helpful Answer
Britain and America Are Two Nations Divided by a Common Language
I though a spanner was a wrench. If this is a broken bit stuck in it, completely remove the collect to take any pressure off. Then usually a small thin flat head screwdriver can be inserted and the bit pushed out.
Score 2
Add a comment
Add your answer
Kristin Cade will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 23
All Time: 315
