Repair and troubleshooting documentation for Frigidaire dishwashers.
11 Questions View all
There is a 1 to 2 inches of water left after cycle ends.
My Frigidaire dishwasher is left with 1-2" of water left after cycle ends. Dishwasher is 10 years old but was never used until 4 months ago. It was working great until last night. It does dry the dishes completely but water won't drain.
1 Comment
I have no blockages and the pump does work during the cycle but it will not drain full at the end of cycle?
by
Add a comment
Chosen Solution
Hi @cadillachawk ,
Try running the drain hose along the floor and into a bucket (or two) and see if it drains normally at the end of the cycle.
If it does then the problem may be a weak drain pump or a faulty impeller in the drain pump.
Check if there is a tech sheet behind the dishwasher’s kick panel (toe panel?) which describes how to run diagnostic tests to speed up the operation of the dishwasher cycle to do the above test.
What is the model number of your dishwasher?
Score 1
4 Comments:
Model# 1.1A 120V 60Hz
by
@Roger Vanderwerf
What is the make and model number of the dishwasher?
You seem to have posted the current/voltage specs of the pump
by
What if the drain works fine at beginning of cycle but doesnt drain at end of cycle? Meaning the mechanical function works fine, it is just not draining at end of cycle??? M# FFBD2406NS10B
by
@Robert J Fox
Check that the drain hose has a loop at a minimum height of 32 inches in order to insure proper drainage.
by
Add a comment
Most Helpful Answer
Reasons why a dishwasher has water at bottom after wash cycle:
1. Sump pump filter/drain basket clogged with food or objects
2. Clogged drain hose Check that your drain hose is HIGH LOOP
3. Check AIR GAP (ANTI SIPHON) if applicable.
4. Drain hose is siphoning
5. Food chopping blade jammed
6. Foreign object lodged in pump
7. Garbage disposal clogged
8. Float is stuck
9. Dishwasher not level
A dishwasher filter/trap/drainage basket that is clogged with chunks of food is the leading reason water remains at the bottom of a dishwasher.
Score 1
3 Comments:
by
I have the same issue, I have the hose dumping into a bucket to remove the air gap and food dispenser variables, and all the water cycles are draining fine as the bucket is full at the end of the cycle but there is always water sitting inside the dishwasher at the end because the very last cycle won't drain the water. So that tells me the pump should be fine but there is something about that last cycle.
by
@albertovira
What is the model number of the dishwasher?
by
Add a comment
How about when they installed the new dishwasher they left a big chunk of styrofoam packing in the bottom of the unit? I found that out today when using a big towel to soak up the water.
Add a comment
Add your answer
Mary Yule will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 44
Past 30 Days: 187
All Time: 33,392
