Scientific calculator by Casio with 252 functions and full dot matrix display. It also features a Replay function and seven variable memory.
11 Questions View all
How to remove f(x) always showing it
in my calculator i cant find any answers because it is always showing f(x) in it
Update (10/17/2017)
in my calculator i cant find any answers because it is always showing f(x) in the screen.how can i remove it?please give an appropriate solution for this
Score 4
Add a comment
Most Helpful Answer
Press Mode at right upper side and then press 1 for COMP. Thank You!!
Score 5
5 Comments:
worked amazingly ,thanks so much!
by
thanks a lot !!!
by
Would this work for a Casio Fx-85GT X ClassWiz? I don't have a MODE button? :(
by
Thank you very much, it works.
by
very effective. thank you!
by
Add a comment
I'd try resetting it. Removing the battery and putting it back should do this: Casio MH-10M Battery Replacement
Hope this helps!
Score 2
Add a comment
Add your answer
anjanakrishna will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 44
Past 30 Days: 229
All Time: 7,557
