The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
628 Questions View all
USB connection problem with iPhone
Hi everybody,
I have a MacBook Air Early 2015 and an iPhone 5s.
When I plug my iPhone into system my iPhone oscillates connecting and disconnecting rapidly.
I did almost everything: changed the cable, cleaned the dock, SMC, NVRAM reset, iTunes reinstall, iPhone's hard reset and restore privacy settings, even did a clean Mac OS install but nothing changes.
With pen drives, MIDI controllers etc... the USB works properly, and it does with my iPhone if I do not log-in into my Mac, just turning it on and plug the USB in. In that case there is no disconnect/reconnect cycling problem. But, immediately after I log-in it starts up.
I was in two different Apple Service and they said that is something software problem and possibly, a clean Mac reinstall solves it. It did not solved it! I tried to connect my iPhone into other notebooks, there were no problem.
Any idea? (Sorry for my poor English...) And yes, the cable is original.
Score 11
7 Comments
What is the MacOS version you are running presently and did you have any issues with your system before? Did it get wet or have something spilled into it?
by
Also, is the cable you are now using an original Apple cable? Some third-party ones don't allow enough power through and therefore demonstrate this problem.
by
Thanks for the answers!
I am running MacOS High Sierra at the moment, but before the update, Sierra did the same thing... I have no other issues before and Mac never got any wet.
The cable is absolutely original, I tried a few other cables too, and bought a new one just because of that symptom. I read a lot about that problem on the internet, many other users all around the World has the same problem but no one has the solution. (not just with iPhones, some iPads do the same thing...)
by
Same problem here, iPad and iPhone cycling power on / off ! what to do ??
by
lots of people have this problem; it the Apple's fault not user error
by
Show 2 more comments
Add a comment
Chosen Solution
At this point I’m suspecting the system has a USB power issue. These are getting hard to find but I think it’s what you need to test things out: USB Charger Doctor - Current & Voltage Charging Detector as well as Battery Voltmeter & Ammeter. With it you should be able to compare the current draw on a second working system (ideally another MacBook Air of the same series) and yours to see if the voltage and/or current draw is the issue. You might want to also try a second iPhone (again the same series would be best comparison).
Score 2
3 Comments:
Yeah, I agree that. I have the same opinion, and I said that to the service 2-3 weeks before... But they answered that it can be just a software problem... Shameful...
by
I had the same problem with my previous macbook air.
Now i lost my old macbook air and got a new one 2 weeks ago, same problem exist. not just my iphone, but also my wife's iphone. Hence, i strongly believe it's the problem of macbook airs.
by the way, i don't buy cables except from apple authorised reseller, i'm certain they're not 3rd party..
previously when i went to the service centre, they say it might be the USB port on my macbook air had wear & tear effect, & repair would cost a lot. But now this new one i bought having the same problem, i am sure it's a problem of macbook air... can anyone in apple try to address this issue and fix this?
by
furoice88 - Is this a brand new, refurb'ed or used system?
Apple does not officially monitor this site so asking Apple for help here won't help you.
The best you can do is bring the MacBook Air back to where you bought it with your iPhone's and cables to show them.
Frankly I would do some tests using the USB Charger Doctor I pointed out above before going.
by
Add a comment
Most Helpful Answer
I was able to fix the issue by restarting the USB service.
sudo killall -STOP -c usbd
Score 86
87 Comments:
Thanks, I hope this will be helpful for peoples who are on the same boat. Unfortunately I sold my MBA, so I can't try it. :(
by
Great solution!
by
Thanks, Man!! Finally got it working.
by
Are you serious, is it this easy? Yes it working %#*@... took me 1,5 years of searching
by
Worked for me yay
by
Show 82 more comments
Add a comment
This command solved my problem. However, I would suggest that for those with little knowledge of Mac, please do the following steps:
1- Go to Application
2- Go to utilities
3- Go to Terminal
4- copy and paste this command in full : sudo killall -STOP -c usbd
5- press Enter
6- It will prompt you for your password, and type your password and hit enter
7- connect your iPhone to mac
8- The problem should be resolved
Best of luck
Score 7
17 Comments:
thanks Sayed Zamir , this helpt me :) , sudo killall -STOP -c usbd
by
Omg Sayed, you are an absolute lifesaver. Thank you!
by
Thank you! This worked for me as well!
by
YES YES YES! Thank you, you computer wizard!! @Sayed Zamir Hashemi
by
Thank you so much Sayed . You really helped me with this, this issue was been troubling me for sooo long.
All thanks to you. :) @Sayed Zamir Hashemi
by
Show 12 more comments
Add a comment
I had the same problem. The problem is caused by cache and directory issues with the startup disk. BOOTING IN SAFE MODE SOLVED IT. Boot in safe mode (hold down shift key immediately you power the macbook, keep holding it until you see the login screen). To confirm that you are in safe mode (safe mode should be written in red at the top right corner of the login screen). Login, plug in your iphone and the problem is solved. To confirm that the problem is solved, leave safe mode by just restarting the macbook normally (without holding shift). Sorry for the late response. THIS IS A 100% FIX
Score 2
6 Comments:
You save my life
by
I can not solved my problem. When i restart my Macbook, problem is not solved. :(
by
The safe mode thing solved the problem right now.
by
Not only did it not work, my USB ports don't work at all in safe mode. Less than 100% fix.
by
Worked like a charm for me too!
by
Show 1 more comment
Add a comment
i have the same problem but a non-Apple lightning cable worked for me! original apple cable won’t stop disconnecting.
4 Comments:
Now here I am: I found a guy, who had the same problem 2 years before. He said that nothing helped him but then he bought a non-Apple lightning cable (ISY IUC-500 type) and it solved everything. I am a little bit skeptic and don't know yet where can I buy that cable but I think it is worth a try.
by
I would find it hard to believe a 3rd party cable would be better than an Apple cable (both being new). The length of the cable could be a factor as an example an overly long cable or one which has a USB extension would have a voltage drop which could explain why your iPhone is having problems as your system is on the edge.
by
I have an 1 m long lightning cable...
by
Don't think thats overly long ;-} A 2 m cable with an extension would be.
by
Add a comment
This post is pretty old but I was about to buy the USB charge doctor to check mine but a coworker suggested I try resetting the SMC on my mac and that fixed it in less than 5 mins. So anyone that’s still dealing with this should try that before buying something to check their USB ports. Here are instructions.
http://osxdaily.com/2010/03/24/when-and-...
Add a comment
This trick works great...but it has to be redone.
Why do I have to do it again? I did it about a month ago, and know I have to redo it. Is this normal or did I forget something? t
Add a comment
Open finder
Look for activity monitor
Open the memory tab and search for usbd
Double click it and press “stop”.
Then it should work.
1 Comment:
Did not work either
by
Add a comment
I plugged the lightning cable to a multiple USB Hub and the Hub to the Macbook pro, and it solved the issue
1 Comment:
this was about a macbook air. Mine works in the pro also, but not in the air
by
Add a comment
Add your answer
Janos Bata will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 127
All Time: 96,246
