An E-Cigarette vaporizer is a device used to heat a substance, such as cannabis or tobacco, to a temperature at which it releases a vapor that can be inhaled. It is a reusable alternative to traditional smoking.
121 Questions View all
How can I change internal battery on an Eleaf Ikuun i200
Hi, I have an Eleaf iKuun i200 vape kit that has an internal battery and I would like the option to be able to change the battery, although, the device has has no way (that I can see) for me to open it up and replace the battery...please advise...kind regards...Bash. gathoobashir@gmail.com
Score 2
1 Comment
Remove the fire button
by
Add a comment
Chosen Solution
All the ones I have seen have threaded bodies. Grap the top in one hand and the bottom in the other and twist open.
Score 2
5 Comments:
Thank you...much appreciated...kind regards
by
Glad I could help ;-)
by
@mayer... Read which mod needs to be fixed before you give advice. I think i200 is made with an internal battery. No twist is possible, just somehow the opening of a glued case.
by
True. 2 batteries are internal. Just removed the one first behind the fire button. I will probably not be enable to fix. Atleast too lazie. Better buy a new one. Problem fixed. ?
by
Hogyan tudom visszarakni a tűzgombot? nem tudom egyszerően visszarakni.
by
Add a comment
Remove the fire button and sticker.
Score 1
Add a comment
Add your answer
Bashir will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 7,810
