Spots on my computer screen.
So my laptop has spots that appear in the screen around the edges and corners. The spots are a Orange-ish yellow-ish tint to it and will often appear in different areas.
I think it has to do with the frame putting pressure on the cable that connects the LCD to the board of your computer. Do they appear in different places if you hold a different spot when you open your laptop? I think its from when you open your laptop. I had a Toshiba that had the slide lock right in the center. Over time, I developed lines right through my screen in that area. I noticed if I pushed on that spot and kinda wiggled, it make them either worse or better. Does moving your screen, or putting pressure in certain spots make it better or worse?
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 206
1 Comment
@cmelopel post some images of what your screen shows with your question. That way we can see what you see. Adding images to an existing question
by oldturkey03
