Repair information and guides for the iPhone 8 that was released on September 22, 2017. Model: A1863, A1905
874 Questions View all
Can I replace the entire rear housing?
I broke the rear glass on my iphone 8. It looks really hard to scrape off the glass and replace that part, so I was wondering if I can replace the entire back of the phone? I could just take out all the parts and transfer them, but the wireless charging coil looks like it's near-impossible to remove successfully. Does anyone know where I can purchase a rear housing including the wireless charging coil? Am I even on the right track with this?
Thanks
Score 6
Add a comment
Most Helpful Answer
You can do it yes.
How to assemble iPhone 8 back housing?
Score 6
3 Comments:
Do you know where I can buy the part including the wireless charging coil?
by
The wireless charging coil can be removed, heating it with the heat gun can make it easy to be removed. The iPhone 8 backhousing is not available now.
by
Mobile sentrix OEM Pulls
But also I heat the back of old housing and crack at glass making wireless charging coil come off or fall out
by
Add a comment
I have kind of the same problem, but - yet still a little worse:
My iPhone 8 has been dropped on a parking lot with an uneven surface - and run over by a car!
So, the entire back housing is bend quite a lot (strangely enough, neither the back glass or the screen seems to be damaged at all).
But it looks odd, and being the skilled industrial technician I am, I’ve tried to bend it back into the correct shape. This cannot be done, since the aluminium kinda hardens the first time it is bend out of shape - and cannot be forced back to its original shape.
So, it would be very appreciated if anyone could help, regarding where I can buy a new back housing.
1 Comment:
Mobile sentrix highly recommended testing the phone with new screen before attempting repair
by
Add a comment
yes you can buy a back glass with mid frame and small parts installed or with a charging coil installed or just bare.
Add a comment
Yes you can however stuff sold in the western world is not cheap which is sourced out of china anyway but below is the link to what you are looking for.
https://www.amazon.ca/Vimour-Housing-Rep...
Add a comment
Add your answer
fdsajky675 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 22
All Time: 10,448
