Repair guides and support for cars and other vehicles produced by the Chrysler division of the Fiat Chrysler Automobiles US LLC.
193 Questions View all
Why is my 2011 chrysler 200 heater blowing warm on one vent?
2011 chrysler 200 my heater is only blowing warm out of the drivers vent only. The rest are blowing cold. it is Not dual climate, it is a single climate control. the defrost, floor well all of it blows cold but drivers vent . when it runs warm then it blows a lil bit warmer. I'm freezing in my car. Any ideas?
Score 2
4 Comments:
I changed the two actuators on my Chrysler 200 and still have heat on drivers side and cold on passenger side. What else do I need to do?
by
We had our 2011 Chrysler taken apart at the shop last year to fix this issue . . . still does the same thing. Blows hot on driver’s side but cold on passenger. It does warm up slightly after a bit. I noticed that the water temperature gage dial stays between C and midway (at 8:00 position) except when it idles for more than 20 minutes sitting in the drive. Then, the heater works great. Almost as soon as we take off, the gage goes back to the 8:00 position and the air on the passenger side is cold again. What the heck? Please, somebody figure this out. Forum posts indicate this is a default situation on this vehicle across the board.
by
Did anyone figure this out? My 2011 Chrysler 200 is doing the exact same thing
by
Do you have the trim level for individual environment control?
by
Add a comment
Be certain it isn't a mouse nest. 2 different cars and 2 motorcycles have been my victims.
Add a comment
I would say your thermostat is stuck. Check to see if it's running at normal temperature.
Add a comment
Add your answer
Billie s. will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 6,449
