How to remove inside calcium from a Hankscraft automatic steam vaporiz
How to remove inside calcium from a Hankscraft steam vaporizer humidifer Model 5592
im not sure about this specific model, but for a generic humidifier, vinegar works.
Pour a generous amount of undiluted white vinegar in to the base of your cool mist humidifier and let sit for 30 minutes. Then remove any residue or build-up by gently scrubbing with the soft bristle brush. Rinse thoroughly. Gently spot clean any remaining pieces and thoroughly rinse the tank, filter, and base.
I may not have provided the complete question. I need to remove the calcium deposit on the steam unit that fits into the base. The steam unit has a couple of screws that hold the steam unit and casing together. Sorry about that.
Unfortunately, i do not have access to the User Manual to share the exact disassembly process, so a manual clean isnt something i can guide you through.
if your user manual doesnt have a disassembly guide, for cleaning, i would suggest calling the manufacturer for further instruction
Try simply spraying some CLR on it and let it sit. It should eventually dissolve the calcium buildup without disassembly.
i WILL GIVE IT A TRY. THANKS FOR YOUR SUPPORT. WILL LET YOU KNOW IF IT WORKS
Your answer requires the highest award that I give. A GOLD STAR
Thanks so much.
Earle
Which solution? Vinegar or CLR?
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 17
All Time: 1,034
