Repair guides and troubleshooting for the Asus ZenWatch 3, a smartwatch that uses the Wear OS.
5 Questions View all
Crown does not working (mid)
My watch works perfect, but the Crosn button is not working.
Score 3
Add a comment
Most Helpful Answer
I had the same problem so took the watch apart with a torx 4 and discovered that the plastic press that the crown pushes against was cracked so being the handy feet thinking female that I am I repaired this by glueing a fragment of false nail over it (with nail glue)
And now reassembled it works perfectly fine
Score 2
Add a comment
I tore the watch down to look at how the buttons work. While the others distinctly click, the middle/crown button felt mushy. I found that if I applied pressure to the circuit board while pressing the crown button, it would click. I put the watch back together and found this to still be true. When the crown button doesn’t work, if I squeeze the watch, face to back, and at the same time press the button, it works. Not an elegant fix, but it works.
Score 1
Add a comment
Add your answer
Sandro will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 835
