Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4995 Questions View all
Water damaged phone turned off and on again
I accidentally dropped my phone in some water and it turned itself off. I was quick to get it out and dry it off. After that I opened it to get the excess water that was in it, which was a few drops of water specifically ion the battery, not much, and disconnect the battery. After letting it dry I reconnected the battery and put it in some rice. Later I took the sim card out which some people said to do. After that my phone turned itself on and back off probably like 5 times. I then tried to connect to a charger and now it hasn't happened again. Have I short circuited the battery? Its it completely done for?
Update (02/24/2018)
Never mind, I was able to make it work by leaving it open and air dry
Score 2
1 Comment
My iPhone 7+ drop into water but I forget to dry it up. Since is water resistant used it charge it and the next day it just keep off and on, but now it just wait no apple logo but it keeps showing charging indicator when it low have check the water damaged indicator but it still intact... What can I do to it can I go screen change or what
by
Add a comment
Chosen Solution
With water damage, you have to decontaminate the logic board before doing anything else, otherwise there will be latent issues down the road.
The water is inside the phone, on the logic board and under the shields, even under the IC's. The real problem is the mineral deposits that can cause short circuits or the corrosion that is taking place as the water evaporates. Leaving the power on the device accelerates the process. The longer you let a phone sit in rice, the more time you are giving corrosion to damage your logic board. The saltier or harder the water is, the more damage will occur. The water needs to be displaced, not evaporated. Here’s a great video that summarizes these issues.
  • Open your phone and remove the logic board (follow this guide)
  • Inspect the logic board, especially around the connectors and look for corrosion.
  • Inspect both sides of the board. Unfortunately, most of the board is covered in shields. That's usually where the damage is occurring.
  • Put your board in a container with >90% isopropyl alcohol and let it sit for a while.
  • Use a soft brush, like a toothbrush and lightly brush away any corrosion you see.
  • Rinse in alcohol and repeat.
  • Let it air dry for a day.
  • Re-assemble and hope for the best.
You should also replace the battery if it has swollen. Resist the temptation to pop it to let the gas out. A compromised Li-ion battery is a fire hazard. If the device appears to power up but behaves erratically, then use a tool like 3uTools to flash the firmware as it may be corrupted.
A professional repair shop that does water damage repair may be able to recover your phone or the data because they have access to pro-level ultrasonic baths and specialized cleaners as well as the skills to troubleshoot your board. Many shops have a no fix/no fee policy so you don't have to spend money to find out if the phone is fixable or not.
Score 4
Add a comment
How does the work you may try to ask the atheist real answer is take it out and try the usb card and the battery put it in rice dry it aging dry your hole phone the case and everything and put it back in the phone it might work I didn’t say it was but I think this is the answer
3 Comments:
Hi,
Rice doesn't solve the problem.
This may be of interest to you.
Rice is for dinner, not repair
by
Purpose of rice isn’t to solve a problem. It’s to absorb water in areas that can’t be reached by other methods such as air drying.
by
Rice does nothing to help your phone.
Rice (or any other desiccant) works by absorbing water vapour. The issue is that as the water in the phone evaporates it leaves minerals deposits which cause short circuits and permanently damage components on the logic board or the modular elements such as cameras. If the salinity of the water is high, then deep corrosion of the components and pcb will occur.
That is the issue with the rice myth...the water vapour is not the issue...leave the phone on the counter and you will get the same result as putting it in a bag of rice. The real solution is to open the device and actively remove or displace the water and clean away any mineral deposits as detailed by my answer above.
by
Add a comment
Add your answer
Random Guy will be eternally grateful.
Past 24 Hours: 18
Past 7 Days: 125
Past 30 Days: 485
All Time: 34,543
