Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
1209 Questions View all
Touch screen crazy behavior
Hello , I´ve a serious problem with my Iphone X , the tactile interface creates random clicks on display. For example if I manage to open the calculator some numbers are not working and in other moments start to type ramdom numbers 88789383... and do on. I´m not sure if the problem would be fixed replacing the complete display assembly or I need to replace other parts.
Regards, Patricio.
Score 4
Add a comment
Chosen Solution
The display is the likely issue here however given that your phone is surely still under warranty, I would suggest you have it replaced by Apple.
If your phone shows any signs of physical damage, they may refuse to to change the screen in which case a reputable third party repair shop can help you out or you can try it yourself.
Score 5
1 Comment:
I'm having. the same problem and asked for a replacement and is doing the same thing, I can only think is that your part is not fully comparable with my phone I'm going to ask for a refund .
by
Add a comment
My phone had become very glitchy. It would type random numbers or change screens on its own or wouldn’t recognize a touch. After calling Apple three times and going to the Apple store twice, they determined I needed a new display. Since it was still under warranty, there was no charge. So far, problems been solved.
Add a comment
I've got an Iphone X, the screen was going crazy opening random apps, impossible to type, etc. I was ready to smash it. I went into display settings and turned off True Tone-it seems to be fixed!
1 Comment:
Why would of that fixed it?
Your only changing the colour of the screen
by
Add a comment
Add your answer
patriciogreco will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 22
All Time: 66,532
