Harley-Davidson Sportster Motorcycles from 1986 to Present.
34 Questions View all
The motor cycle dies after about 30 seconds
i have a 95 sportster battery is showing 12.5v and a full tank of premium fuel , the bike starts and runs for about 30 sec and dies, i can see the gas spraying but the bike won`t stay running
1 Comment:
If it is a carburettor than most likely it is the idle circuit. Take a look at your filter, is the fuel running through that OK? You might need to pull your carb and give it a thorough clean.
by
Add a comment
1 Answer
This sounds like a gas issue , has it been sitting up ? I would check carb , It may be gunk up from sitting with gas in it , if this helps you great , if not reply
2 Comments:
also check fuel flow , it can also be not flowing good , (check for TANK TRASH if flow is not good)
by
It sat over the winter on a battery tender and had it tuned up before winter, well I took the tank off to paint it which all I dissconnected was the crossover fuel hose that leads from obe side of the tank to the other and the 2 fuel hoses on the petcock I took the petcock off to paint, well when I put it back on the bike and start it, it only runs for about 15-30 seconds I see the fuel spraying in the carb
by
Add a comment
Add your answer
chris clayton will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 35
All Time: 1,901
