Repair guides and support for the second generation Honda Insight.
10 Questions View all
Why do the electric passenger windows quit working?
How can I fix the problem of the passenger windows when they stop working. The drivers window works fine but the other three windows suddenly stop. Is there a part that I can replace and what is making that part die?
1 Comment
Does the drivers side switch operate the window on the passenger side?
by
Add a comment
1 Answer
Chosen Solution
There are many reasons the widow wont work . It could be the regulator , the electric motor, the switch on the passenger door , the switch on the drivers door , but the most common problem is the wires in the door were they pass through the door hing . as the door opens and closes the wires flex and bend and eventually break . Your best bet is to get out your multi meter and do some testing .Hope this helps
Score 3
Add a comment
Add your answer
William Salzwedel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 18
All Time: 298
