The first generation of the Chevrolet Aveo, identifiable by the internal code T200, the T250 being a facelifted model. This vehicle is also sold as a Pontiac G3, Daewoo Kalos or Pontiac Wave.
22 Questions View all
2008 Chevy aveo oil light.
When car is running and I come to a stop, the oil light flickers but when it is running the light is off.
All the oils are fine, put in new oil pressure sensor, there is no knocking. What can be causing this.
Score 2
Add a comment
Most Helpful Answer
'''++@velazqc++'''
could be caused by bad oil pump, engine bearings as well as multitude of other things. Start by changing your oil and install a new oil filter.
Score 1
Add a comment
ماهو سبب عدم سرعا في اطلعا
Mise à jour (16/07/2022)
MWhat is the reason for not speeding the car in Atlaa
1 Comment:
What? Can you perhaps try explaining what you mean so we can help you?
by
Add a comment
Please do two things
One took out the Battery negative terminal and wait for 5 minutes and again place it back the problem will go
Second open the petrol tank cover and wait for 5 seconds and put it back the light will disappear
Try this
Add a comment
Change the oil pressure sensor
Score -1
Add a comment
Add your answer
Carmen Velazquez will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 38
All Time: 2,131
