Smok X-Priv will not heat up coil
My xpriv voltage stays at 0.500 volts and the coil wont heat up the tank works on other mods. Can someone please help me
I know this is an old post but I solved the problem and I just want to leave it here in case someone needs it,
all you need to do is open the part on top of the batteries which requires a torx 4 screwdriver, then you will see a little black box on the left which is most likely loose, just put some paper on top of it or anything that can push it down towards the plastic and you will be good to go.
***Put a little paper here to press down
Wish I could take photo. I’ll try with words
| Glass |
______________________________| . |
| black. Electrics
|. Chip.
Negative Negative
Battery. Battery
Positive. Positive
Battery. Battery
____________________________________
thank you so much for this it worked!!
I have not yet tried this but thank you very much I am almost certain this is also my problem
This finally resolved my problem the whole year sometime it would just stop working and now it's fixed🫡
Fully works! You need to properly wedge it in there but it's running normally now.
I had a simmilar problem on my SMOK x-priv. If you look in the bottom right corner there is a timer, that should track how long the current puff is.
The problem was that it was just continuesly resetting the timer and firing constantly for a split second each time. at such a low voltage where it wouldn't heat the coil enough.
If your timer is also stuck at 0.1s all while holding the trigger, take it back to the store.
It still has the timer count to 10. I can hold my finger on the coil the entire time(i know stupid, but no heat at all)
Still, just return it to your local store, and they should take it in, if it's within the items waranty, which mine still was after they saw my issue. Conclutuion was a chipset failure.
I bought it from ebay seller not available now
Mine is just like yours timer stuck at .1 secs
mines also stuck at .1 secs smh
Check all the internal settings, watts, etc. Take the coil out and reinstall, prime, reset internal settings to new coil, etc. Coil might not be installed right enough or maybe it burnt if not primed properly first time. Charger plugged in should tell you how full batteries are…fully charge for several hours. Ohms should be about .4 and volts should be 4-5 if it's the original pieces in the kit. 60 watt setting should be fine depending on juice. Coil should be fine well above this. Picked up mine last week and love it.
I have the same issue. The only thing that helps is changing to fresh batteries or plugging in with USB charger and charging the batteries to 75 to 100%.. Usually at 50% battery level, it stops firing and only goes up to .5 volts.
Had same issues even though my batter indicator says 50% no fire put 100% batteries in and bam it hit got 4 batteries swapping 2-3 times a day waiting for new 3000 mah i never turned if off for first few weeks now i do to conserve battery .
I like my V8 baby beast tank better than the
V12 this has kept me from smoking
Cigarettes for 10 months on vaping having some fun with it and my breathing is
Drastically better by better than 100%
Hi guys, I know this is a old post but for anyone looking in the future I was having the same problem and fixed mine after finding this YouTube comment. You will need a T6 screwdriver/ bit
My X-Priv did this. So bought another, and put it in the drawer. 1 year later, I decide to look into it & fix. Came across this (more so the comments below) and fixed it. Dead simple, as others have said. 1.) Remove battery cover 2.) Remove top magnet cover (not bottom) 3.) Locate little black box, confirm its that causing the problem by applying pressure/moving till device works correctly 4.) Use something like folded up electric tape or similar, to hold it in place so that there is additional pressure applied once cover is re-fitted. 5.) Put back together, and use.
I used a bit of folded up tissue and screwed the panel back on anything non conducive should be fine.
Well, i was having the same problem,
first, my batteries went completely ZERO charge,
then, mod-cable connected to usb, wouldn’t even display any charging process,
I finally buy new batteries some brown samsung, and left mine (some purple ones) charging at vape store,
when installing batteries, it wouldn’t fire any vape.
when remove and reinstall atomizer, screen said NO ATOMIZER, and then SHORT IN ATOMIZER…
After cleaning, and cleaning and drying and drying and trying, it random the activity between “no fire and stuck in no puff count nor time count” and then displayed LOW OHMS .016…
i remove new batteries and place them to charge in my new independent charger, then, after 10 mins maybe, i installed those batteries in my xpriv mod, and connect the charging cable with a regular usb charger (NO IPHONE, NOR IPAD charger they said that at the store!!!) regular, regular chinese slow charger.
It fixed the no fire, and worked!!! first depended on being connect to charger cable, and it wouldn’t fire if disconnect.
Then after a few minutes start working regularly, even if disconnected.
I’m guessin maybe theres a charge inside the mod, and when batteries die to ZERO it loses ohms or something…
I bought one and I accidentally dropped it but not a major drop basically just knocked it down and when I tried it again, the timer wouldn't go past 1. It's wouldn't heat up. Everything else on settings is okay but the seconds won't go up. So I went out and bought a new one same one different color and after a week it started to do the same thing!!! I don't know if it's just a bad product overall but come on?! Twice?? I tried everything new tank, new batteries, new charger…nothing worked. I just went and bought a different one. I was so disappointed in SMOK! :’( Does anyone know how to fix this problem?? I wouldn't mind having an extra one at home, a back up one.
I am having the same problem. Have you gotten any answers to this that that has fixed the problem??
No never got an answer to fix that issue. did u?
It’s a battery problem for me but my batteries are brand new, I plugged it in and when my batteries got down to about 60% it did not like it, if you can hit it for like 2 seconds on the charger then let batteries change for a bit, that fixed my issue
I have the smoke TPRIV it was saying ohm's low .I seen a video that said to change the mod/tank I did it and miraculously it worked!! For about two seconds shmmfh! Now it is completely blank like it's dead . I got it not to long ago and it's like Brand new .
Old post
I had this problem now. Opened up the 2 hex screens on top part of mod near tank and the voltage regualor fell out. I put it back in with the writing facing towards the tank and jammed a piece of tissue in there then closed it. Now it works fine. Should probably solder it back in. Will do that later. Hope this helps
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 45
All Time: 37,539
8 Comments
Hi deline_664 what batteries did you use and had you check your batteries?
by Augustine
Samsung INR18650
havent checked batteries yet. Do you recommend buying a new set to try??
by deline_664
Hi deline_664, before you purchase, get a multimeter to check if the voltage
you should be getting around 3.3 to 4.2V
by Augustine
I have the same issue, battery’s are fine, tried 3 diff tanks and I have another device same model that my wife uses it works with all my tanks. Switched batteries to no avail same issue
by Osmond Jr. Haughton
mines also stuck at .1 ohms smh
by ryandemesa
Show 3 more comments
