An E-Cigarette vaporizer is a device used to heat a substance, such as cannabis or tobacco, to a temperature at which it releases a vapor that can be inhaled. It is a reusable alternative to traditional smoking.
121 Questions View all
G Priv Baby Luxe Bricked, need 1.0.1 Firmware
Similar to a guy I saw on here with a T-Priv 3, I bricked my mod after doing a firmware update wrong. I require the stock firmware for a G Priv Baby Luxe in order to get my baby working again, any help would be amazing.
Score 6
3 Comments
I have the same issue and in search for the stock firmware for this mod.
by
Hi. I found a great place where I can get all the vaping products I need and I thought I should share it with everyone.
It’s called Vaperite. Check them out https://buff.ly/3P5BF9b
by
Gwam stands for Global Wholesale and Marketing and it is an online store that bridges the gap between you and products from all around the world.
The exclusive distributor for our esteemed products <a href="https://gwam.pk/product-tag/wape/">Aroma King</a>,<a href="https://gwam.pk/product-category/pods/sm...> Smok</a>, <a href="https://gwam.pk/product-category/pods/vo...>Voopoo</a>, and <a href="https://gwam.pk/product-tag/caliburn-pri...>Caliburn</a> is Global Wholesale and Marketing (Private) Limited. It is renowned for providing the best import services in recent years and brings all varieties of pods, vapes, and energy drinks to your table in high-quality.
by
Add a comment
Most Helpful Answer
Thanks to Danillo for solving this problem.
To revert your currently brick mod back to the stock firmware you need to download the Nuvoton firmware update software from Smok’s website and the original firmware bin file.
Remove the battery from your Smok device
Open Nuvoton NuMicro ISP Programming Tool 2.00
Hold the fire button on your Smok device and connect to you computer using the micro-usb cable (you have to hold the fire button during the entire process)
Once device is connected to the computer you should get a device connected notification on your computer. On the Nuvoton window click Continue and then Connect on the next screen
Click on APROM and select the stock firmware .bin file you have downloaded and ☑ the following
Click Start and your device should be fixed
Score 3
1 Comment:
Thanks a lot..
by
Add a comment
I have the same issue, I think I installed a G-Priv II 1.0.5 firmware instead and now it won't boot. is there a way to format it back to 1.0.1?
Score 1
1 Comment:
Do you fix your proplem i had de same issue
by
Add a comment
Does someone has a solution for this? Where to download the original firmware?
Score 1
Add a comment
I made the same mistake. I have emailed smoktech support. Has anyone still found any solution?
Score 1
1 Comment:
Apparently smok after sales service told me to install the firmware! Where the Effin Eff is the firmware? Bunch of idiots!
by
Add a comment
hola he cometido el mismo error que necesito la solución wtf
Score 1
1 Comment:
Hallo habe die original Firmware für die G-Priv Baby! Kann sie per E-Mail zukommen lassen!
by
Add a comment
Score 1
15 Comments:
please send to me edwinval.reyes@gmail.com
by
can you email it to me too ?? jimilvineyard96@hotmail.com
by
please send to me, please : totti953@hotmail.com
by
please sent it to me yunghoe23@gmail.com
by
I need it please! eduvicma@hotmail.com
by
Show 10 more comments
Add a comment
yea, and dont forget to send it to me pls!!!!!!!!!!!!!!
yveso45@gmail.com
Score 1
1 Comment:
Can you plz send to me too...
Dventura517@gmail.com
by
Add a comment
May I have the original firmware sent to me as well please. for the gprive baby lux email to forever4lala@gmail.com
1 Comment:
do you have firmware E-PRIV
by
Add a comment
arslanfurkan999@gmail.com
Add a comment
Hi, pls send for me too
barthagery@gmail.com
Add a comment
Add your answer
knroo6 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 25
All Time: 5,822
