The Brother XR-40 is a 35 stitch, drop arm sewing machine featuring a sewing assist LCD display.
6 Questions View all
Wrong volts placed instead of correct one
I placed my sewing machine wrongly in 220 v instead of 110v now the machine is nt working
Score 1
Add a comment
1 Answer
Chosen Solution
Reena Cyril  from teh schematic it looks like the power wire mounts straight to the motor. In that case it is most likely your motor that has burned out. See if you can take a better look at the motor etc. once you partially disassemble your machine. Use this guide Brother XR-40 Stitch Select Knob Replacement to get to it and use this guide to post some images of what you find with your question. That way we can see what you see. Adding images to an existing question
iFixit Image
Guide
Difficulty:
Very easy
2 - 5 minutes
Brother XR-40 Stitch Select Knob Image
Guide
Difficulty:
Moderate
10 minutes
Score 3
Add a comment
Add your answer
Reena Cyril will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 191
