Also known as a multitester, or a VOM (Volt-Ohm meter), a multimeter is an electronic measuring instrument used to measure voltage, current, and resistance. Includes handheld and tabletop testing devices.
39 Questions View all
Non-contact voltage detector not working on Multi Meter
Hi,
I bought a Multimeter from JayCar Electronics today Digitech QM1529 DVM. It works fine but one thing doesn’t work, the non-contact voltage detector.
When I try to use it with the DVM it comes up with - 951 when I’m not even holding it up to something!
I hope there is a fix
1 Comment
Robbie1155 are you following the manual for this meter?
by
Add a comment
1 Answer
Chosen Solution
Sorry you have a bad unit you’ll need to return it for an exchange or buy another probe.
Score 1
1 Comment:
Thanks I will exchange it :)
by
Add a comment
Add your answer
Robbie1155 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 609
