Sandwich heater grill - 230 volts - 50 Hz - 2000 Watts
5 Questions View all
Repairing Breville TG400 Sandwich Maker
When I insert my toaster to the plug the electricity at my house goes down. I’m sure that it is easy to fix that problem. I opened the toaster and everything looks fine. Maybe the plug itself is the problem? Should I replace it?
Add a comment
1 Answer
Chosen Solution
If it is blowing the circuit breaker by just being plugged in, I would replace the plug in cable first.
Score 2
1 Comment:
You might also want to clean some of the dirt on the pins.
Also what else is on the same breaker line you maybe overloading the circuit.
What is the breaker or fuse rating for the outlet you are using.
by
Add a comment
Add your answer
Eden Bensal will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 37
All Time: 1,560
