My brake light on dash stays on
Parking brake switch, brake light on dash stays on
Hi @pissingmeoff ,
The “brake” indicator light in the dash has two functions.
It indicates that the parking brake is applied and it is also a low brake fluid level warning light.
If the light is on with the ignition on but the parking brake is released then first check the brake fluid reservoir to ensure that the brake fluid level is correct.
If it is OK then perhaps there may be a faulty sensor in the reservoir or the parking brake switch may be faulty
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 33
All Time: 3,254
2 Comments
You could bring it to the nearest Mechanic shop and get it fixed there.
by First Name Last Name
Had all that fixed and it’s still on
by James
