How do you change the transmission fluid in the Model S?
Has anyone looked into how to change the single gear transmission fluid in the Model S?
Stephen Leung this should help you out:
Gearbox Fluid - Front (Remove and Replace)
FRT No: 39300102
Special tool required for this procedure:
SupplierPart NumberDescriptionTesla1054946-00-AFluid Transfer Pan
Gearbox Fluid - Large Rear Drive Unit (Remove and Replace)
FRT No: 40300102
''Warning: If the vehicle has air suspension, activate "Jack" mode on the touchscreen before raising and supporting the vehicle.''
''Caution: Do not attempt to fill the drive unit through the upper plug.''
Toe link
Shock absorber
This is a guide on how to replace the transmission fluid for the S P85 model. I believe they’re all rather similar in terms of design.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 28
All Time: 4,561
2 Comments
What kind of oil should I pour into the Tesla model s differential
by peretiatkoaa
sorry for my english
by peretiatkoaa
