The Samsung RF22KREDB is a French door refrigerator with a 21.8 cu. ft. total capacity, featuring a counter-depth design, spillproof glass shelves, humidity-controlled crispers, and a FlexZone drawer for adjustable temperature control. It has dimensions of 35 3/4 in. x 70 in. x 28 1/2 in. and includes a dispenser for cubed ice, crushed ice, and chilled water.
3 Questions View all
Samsung ice maker stopped making ice
I have a 1.5 year old 5 door Samsung refrigerator freezer. All of a sudden it stopped making ice. Videos and questions say to remove the door and reset but I can't even get the door off to get at the reset button. Any suggestions.
Score 3
3 Comments
Hi @crazygma ,
What is the model number of the refrigerator?
by
rf22kredbsg/aa
by
Unfortunately, there is most likely an ice jam inside of the ice bucket, you will have to do a 'forced defrost' in order to melt the jammed ice thats inside the bucket before you will be able to pull it out and get to the test/reset button.
by
Add a comment
1 Answer
Chosen Solution
Cause 1
Freezer Temperature is Above 10 Degrees F (-12C)
If the freezer temperature is above 10 degrees Fahrenheit (-12C), the ice maker will not produce ice cubes efficiently. The freezer temperature should be set between 0 and 5 degrees Fahrenheit (-18 to -15C) for the ice maker to work properly. If the freezer temperature is too high, ensure that the condenser coils are clear of debris and the condenser fan is working properly. In addition, check to see if frost has accumulated on the evaporator coils. If the evaporator coils are frosted over, part of the defrost system has likely failed.
Cause 2
Water Inlet Valve
The water inlet valve is an electrically-controlled valve that opens to supply water to the dispenser and ice maker. If the water inlet valve is defective, or if it has insufficient pressure, it won’t allow water to flow through. As a result, the ice maker won’t make ice. The valve requires at least 20 psi to function properly. Make sure that the water pressure to the valve is at least 20 psi. If the water pressure is sufficient, use a multimeter to check for power to the water inlet valve. If the water inlet valve has sufficient pressure and is getting power, but the ice maker won’t fill with water to make ice, replace the water inlet valve.
Cause 3
Ice Maker Assembly
One component of the ice maker assembly might be defective. Since many of the ice maker components are not sold separately, you may need to purchase and replace the entire ice maker assembly. Before replacing the ice maker assembly, check the water inlet valve, water line, and fan. If none of these parts are at fault, and the freezer temperature is at least 15 degrees Fahrenheit, replace the ice maker assembly.
Cause 4
Low Water Pressure from House Supply
The home may have insufficient water pressure. The water inlet valve supplies water to the ice and water dispenser. The water inlet valve requires a minimum of 20 psi to function properly. Check the water flow and test the pressure to determine if it is at least 20 psi.
Cause 5
Door Switch
The door switch turns off the ice and water dispenser when the refrigerator door is open. If the door switch fails, the dispenser will not turn on. To determine if the door switch is defective, use a multimeter to test it for continuity. If the door switch does not have continuity when activated, replace it.
Score 3
Add a comment
Add your answer
Carol will be eternally grateful.
Past 24 Hours: 8
Past 7 Days: 41
Past 30 Days: 155
All Time: 64,864
