Where is the ac drain line located exactly?
I have a stale smelling coming from my ac. In my 2011 Nissan Pathfinder. Can someone tell me step by step where the drain line is
I had this problem with a 2007 Pathfinder.
I found if you remove the passenger front tire, and the plastic wheel covering inside the wheel well, you can access the heater core lines easier. Then the drain hose is behind those. It's very hard to see it from under the car.
An exact location will be hard to define. But, It will come out of the firewall, passenger side, low on the firewall. You’ll see a black tube probably with an I.D. of 5/16th’s hanging straight down. What I’ve found to be most likely problem is the floor mat will get pushed up kinking it inside where it comes off the evaporator box. Could be debris has got into evap then has clogged it. It should be fairly easy to see from the passenger side floor. All else fails, take it off and blow through it. To get rid of the smell. I recommend using “Ozium” spray. Set your controls on Recirculate, low fan speed then spray it at bottom of evaporator box ( give it a good long spray). That way it will get sucked into evap core. Then shut it all down, let it sit for as long as you can. It will kill any bacteria. I’d give it a shot of it from time to time just to keep it clean. Hope this helps.
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 81
All Time: 1,852
