Repair guides and support for motorcycles manufactured by Kawasaki.
23 Questions View all
oil leak from water pump
I have a oil leak coming out of the drain tube from water pump ,thinking it may be coming through seal around water pump shaft , there is no sign of coolant in engine oil this on a Brute force 650 4x4i , 2006
Score 1
Add a comment
1 Answer
Chosen Solution
It sounds highly likely that you are correct on the bad seal or gasket (not limited to the water pump shaft). If the oil pressure is higher than the coolant pressure that would explain no coolant in the oil.
Add a comment
Add your answer
Danny Rabon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 22
All Time: 1,948
